Errors on compiling for makerbase board
I have makerbase robin nano v2 board for 3D printer. github has 2 year old files that dont work.
Lates marlin compiles ok but when change board to robin it start making errors.
I fixed some errors, build_src_filter was wrong way.(src_build_filter). It was 2 years ago working but some updates as i seem.platformio.
Here to github https://github¨dotcom/makerbase-mks/Mks-Robin-Nano-Marlin2.0-Firmware
edit: modified links to make post
clip of errors:> Library Manager: Installing +<src/lcd/menu>
VCSBaseException: VCS: Unknown repository type +<src/lcd/menu>:
File “C:\Users\OMISTAJA.platformio\penv\Lib\site-packages\platformio\builder\main.py”, line 173:
env.SConscript(“$BUILD_SCRIPT”)
File “C:\Users\OMISTAJA.platformio\packages\tool-scons\scons-local-4.5.2\SCons\Script\SConscript.py”, line 598:
File “C:\Users\OMISTAJA.platformio\packages\tool-scons\scons-local-4.5.2\SCons\Script\SConscript.py”, line 285:
here is beginning of ini
# Marlin Firmware
# PlatformIO Configuration File
# For detailed documentation with EXAMPLES:
# docs.platformio.org/en/latest/projectconf/index.html
# Automatic targets - enable auto-uploading
#targets = upload
# By default platformio build will abort after 5 errors.
# Remove '-fmax-errors=5' from build_flags below to see all.
[platformio]
src_dir      = Marlin
boards_dir   = buildroot/share/PlatformIO/boards
default_envs = mks_robin_nano35
include_dir  = Marlin
# The 'common' values are used for most Marlin builds
[common]
default_build_src_filter = +<src/*> -<src/config> -<src/HAL> +<src/HAL/shared>
  -<src/lcd/HD44780> -<src/lcd/dwin> -<src/lcd/dogm> -<src/lcd/tft>
  -<src/lcd/menu>
  -<src/lcd/menu/game/game.cpp> -<src/lcd/menu/game/brickout.cpp> -<src/lcd/menu/game/invaders.cpp>
  -<src/lcd/menu/game/maze.cpp> -<src/lcd/menu/game/snake.cpp>
  -<src/lcd/menu/menu_backlash.cpp>
  -<src/lcd/menu/menu_bed_corners.cpp>
  -<src/lcd/menu/menu_bed_leveling.cpp>
  -<src/lcd/menu/menu_cancelobject.cpp>
  -<src/lcd/menu/menu_delta_calibrate.cpp>
  -<src/lcd/menu/menu_filament.cpp>
  -<src/lcd/menu/menu_info.cpp>
  -<src/lcd/menu/menu_job_recovery.cpp>
  -<src/lcd/menu/menu_led.cpp>
  -<src/lcd/menu/menu_media.cpp>
  -<src/lcd/menu/menu_mmu2.cpp>
  -<src/lcd/menu/menu_password.cpp>
  -<src/lcd/menu/menu_power_monitor.cpp>
  -<src/lcd/menu/menu_spindle_laser.cpp>
  -<src/lcd/menu/menu_temperature.cpp>
  -<src/lcd/menu/menu_tmc.cpp>
  -<src/lcd/menu/menu_touch_screen.cpp>
  -<src/lcd/menu/menu_ubl.cpp>
  -<src/lcd/extui/lib/mks_ui>
  -<src/lcd/extui/lib/dgus> -<src/lcd/extui/dgus_lcd.cpp>
  -<src/lcd/extui/example.cpp>
  -<src/lcd/extui/malyan_lcd.cpp>
  -<src/lcd/extui/lib/ftdi_eve_touch_ui>
  -<src/lcd/extui/lib/anycubic_i3mega>
  -<src/lcd/extui/anycubic_tft.cpp>
  -<src/lcd/lcdprint.cpp>
  -<src/sd/usb_flashdrive>
  -<src/feature/backlash.cpp>
  -<src/feature/baricuda.cpp> -<src/gcode/feature/baricuda>
  -<src/feature/bedlevel/abl> -<src/gcode/bedlevel/abl>
  -<src/feature/bedlevel/mbl> -<src/gcode/bedlevel/mbl>
  -<src/feature/bedlevel/ubl> -<src/gcode/bedlevel/ubl>
  -<src/feature/binary_stream.cpp> -<src/libs/heatshrink>
  -<src/feature/bltouch.cpp>
  -<src/feature/cancel_object.cpp> -<src/gcode/feature/cancel>
  -<src/feature/caselight> -<src/gcode/feature/caselight>
  -<src/feature/closedloop.cpp>
  -<src/feature/controllerfan.cpp> -<src/gcode/feature/controllerfan>
  -<src/feature/dac> -<src/feature/digipot>
  -<src/feature/direct_stepping.cpp> -<src/gcode/motion/G6.cpp>
  -<src/feature/e_parser.cpp>
  -<src/feature/encoder_i2c.cpp>
  -<src/feature/fanmux.cpp>
  -<src/feature/filwidth.cpp> -<src/gcode/feature/filwidth>
  -<src/feature/fwretract.cpp> -<src/gcode/feature/fwretract>
  -<src/feature/host_actions.cpp>
  -<src/feature/hotend_idle.cpp>
  -<src/feature/joystick.cpp>
  -<src/feature/leds/blinkm.cpp>
  -<src/feature/leds/leds.cpp>
  -<src/feature/leds/pca9533.cpp>
  -<src/feature/leds/pca9632.cpp>
  -<src/feature/leds/printer_event_leds.cpp>
  -<src/feature/leds/tempstat.cpp>
  -<src/feature/max7219.cpp>
  -<src/feature/mixing.cpp>
  -<src/feature/mmu2> -<src/gcode/feature/prusa_MMU2>
  -<src/feature/password> -<src/gcode/feature/password>
  -<src/feature/pause.cpp>
  -<src/feature/power.cpp>
  -<src/feature/power_monitor.cpp> -<src/gcode/feature/power_monitor>
  -<src/feature/powerloss.cpp> -<src/gcode/feature/powerloss>
  -<src/feature/probe_temp_comp.cpp>
  -<src/feature/runout.cpp> -<src/gcode/feature/runout>
  -<src/feature/snmm.cpp>
  -<src/feature/solenoid.cpp>
  -<src/feature/spindle_laser.cpp> -<src/gcode/control/M3-M5.cpp>
  -<src/feature/tmc_util.cpp> -<src/module/stepper/trinamic.cpp>
  -<src/feature/twibus.cpp>
  -<src/feature/z_stepper_align.cpp>
  -<src/gcode/bedlevel/G26.cpp>
  -<src/gcode/bedlevel/G35.cpp>
  -<src/gcode/bedlevel/G42.cpp>
  -<src/gcode/bedlevel/M420.cpp>
  -<src/gcode/calibrate/G33.cpp>
  -<src/gcode/calibrate/G34_M422.cpp>
  -<src/gcode/calibrate/G76_M871.cpp>
  -<src/gcode/calibrate/G425.cpp>
  -<src/gcode/calibrate/M12.cpp>
  -<src/gcode/calibrate/M48.cpp>
  -<src/gcode/calibrate/M100.cpp>
  -<src/gcode/calibrate/M425.cpp>
  -<src/gcode/calibrate/M666.cpp>
  -<src/gcode/calibrate/M852.cpp>
  -<src/gcode/config/M43.cpp>
  -<src/gcode/config/M217.cpp>
  -<src/gcode/config/M218.cpp>
  -<src/gcode/config/M221.cpp>
  -<src/gcode/config/M281.cpp>
  -<src/gcode/config/M302.cpp>
  -<src/gcode/config/M305.cpp>
  -<src/gcode/config/M540.cpp>
  -<src/gcode/control/M7-M9.cpp>
  -<src/gcode/control/M211.cpp>
  -<src/gcode/control/M605.cpp>
  -<src/gcode/feature/advance>
  -<src/gcode/feature/camera>
  -<src/gcode/feature/i2c>
  -<src/gcode/feature/L6470>
  -<src/gcode/feature/leds/M150.cpp>
  -<src/gcode/feature/leds/M7219.cpp>
  -<src/gcode/feature/macro>
  -<src/gcode/feature/mixing/M163-M165.cpp>
  -<src/gcode/feature/mixing/M166.cpp>
  -<src/gcode/feature/pause/G27.cpp>
  -<src/gcode/feature/pause/G60.cpp>
  -<src/gcode/feature/pause/G61.cpp>
  -<src/gcode/feature/pause/M125.cpp>
  -<src/gcode/feature/pause/M600.cpp>
  -<src/gcode/feature/pause/M603.cpp>
  -<src/gcode/feature/pause/M701_M702.cpp>
  -<src/gcode/feature/trinamic/M122.cpp>
  -<src/gcode/feature/trinamic/M569.cpp>
  -<src/gcode/feature/trinamic/M906.cpp>
  -<src/gcode/feature/trinamic/M911-M914.cpp>
  -<src/gcode/geometry/G17-G19.cpp>
  -<src/gcode/geometry/G53-G59.cpp>
  -<src/gcode/geometry/M206_M428.cpp>
  -<src/gcode/host/M16.cpp>
  -<src/gcode/host/M113.cpp>
  -<src/gcode/host/M360.cpp>
  -<src/gcode/host/M876.cpp>
  -<src/gcode/lcd/M0_M1.cpp>
  -<src/gcode/lcd/M145.cpp>
  -<src/gcode/lcd/M250.cpp>
  -<src/gcode/lcd/M73.cpp>
  -<src/gcode/lcd/M995.cpp>
  -<src/gcode/motion/G2_G3.cpp>
  -<src/gcode/motion/G5.cpp>
  -<src/gcode/motion/G80.cpp>
  -<src/gcode/motion/M290.cpp>
  -<src/gcode/probe/G30.cpp>
  -<src/gcode/probe/G31_G32.cpp>
  -<src/gcode/probe/G38.cpp>
  -<src/gcode/probe/M401_M402.cpp>
  -<src/gcode/probe/M851.cpp>
  -<src/gcode/probe/M951.cpp>
  -<src/gcode/scara>
  -<src/gcode/sd>
  -<src/gcode/temp/M104_M109.cpp>
  -<src/gcode/units/G20_G21.cpp>
  -<src/gcode/units/M149.cpp>
  -<src/libs/L64XX> -<src/module/stepper/L64xx.cpp>
  -<src/libs/hex_print.cpp>
  -<src/libs/least_squares_fit.cpp>
  -<src/libs/nozzle.cpp> -<src/gcode/feature/clean>
  -<src/module/delta.cpp>
  -<src/module/planner_bezier.cpp>
  -<src/module/printcounter.cpp>
  -<src/module/probe.cpp>
  -<src/module/scara.cpp> -<src/gcode/calibrate/M665.cpp>
  -<src/module/stepper/TMC26X.cpp>
extra_scripts      =
  pre:buildroot/share/PlatformIO/scripts/common-dependencies.py
  pre:buildroot/share/PlatformIO/scripts/common-cxxflags.py
build_flags        = -fmax-errors=5 -g -D__MARLIN_FIRMWARE__ -fmerge-all-constants
lib_deps           =
# Feature Dependencies
[features]
HAS_TFT_LVGL_UI         = lvgl=github¨dotcom/makerbase-mks/LVGL-6.1.1-MKS/archive/master.zip
                          build_src_filter=+<src/lcd/extui/lib/mks_ui>
                          extra_scripts=download_mks_assets.py
USE_WIFI_FUNCTION       = qr_encode=github¨dotcom/MKS-Sean/qr_encode/archive/master.zip
HAS_TRINAMIC_CONFIG     = TMCStepper@~0.7.1
                          build_src_filter=+<src/feature/tmc_util.cpp> +<src/module/stepper/trinamic.cpp> +<src/gcode/feature/trinamic/M122.cpp> +<src/gcode/feature/trinamic/M906.cpp> +<src/gcode/feature/trinamic/M911-M914.cpp>
HAS_STEALTHCHOP         = build_src_filter=+<src/gcode/feature/trinamic/M569.cpp>
SR_LCD_3W_NL            = SailfishLCD=github¨dotcom/mikeshub/SailfishLCD/archive/master.zip
HAS_I2C_DIGIPOT         = SlowSoftI2CMaster
                          build_src_filter=+<src/feature/digipot>
HAS_TMC26X              = TMC26XStepper=github¨dotcom/trinamic/TMC26XStepper/archive/master.zip
                          build_src_filter=+<src/module/TMC26X.cpp>
HAS_L64XX               = Arduino-L6470@0.8.0
                          build_src_filter=+<src/libs/L64XX> +<src/module/stepper/L64xx.cpp> +<src/gcode/feature/L6470>
NEOPIXEL_LED            = Adafruit NeoPixel@1.5.0
                          build_src_filter=+<src/feature/leds/neopixel.cpp>
MAX6675_IS_MAX31865     = Adafruit MAX31865 library@~1.1.0
HAS_GRAPHICAL_LCD       = U8glib-HAL@0.4.1
                          build_src_filter=+<src/lcd/dogm>
USES_LIQUIDCRYSTAL      = LiquidCrystal@1.5.0
USES_LIQUIDTWI2         = LiquidTWI2@1.2.7
DWIN_CREALITY_LCD       = build_src_filter=+<src/lcd/dwin>
HAS_CHARACTER_LCD       = build_src_filter=+<src/lcd/HD44780>
HAS_GRAPHICAL_TFT       = build_src_filter=+<src/lcd/tft>
HAS_LCD_MENU            = build_src_filter=+<src/lcd/menu>
HAS_GAMES               = build_src_filter=+<src/lcd/menu/game/game.cpp>
MARLIN_BRICKOUT         = build_src_filter=+<src/lcd/menu/game/brickout.cpp>
MARLIN_INVADERS         = build_src_filter=+<src/lcd/menu/game/invaders.cpp>
MARLIN_MAZE             = build_src_filter=+<src/lcd/menu/game/maze.cpp>
MARLIN_SNAKE            = build_src_filter=+<src/lcd/menu/game/snake.cpp>
HAS_MENU_BACKLASH       = build_src_filter=+<src/lcd/menu/menu_backlash.cpp>
HAS_MENU_BED_CORNERS    = build_src_filter=+<src/lcd/menu/menu_bed_corners.cpp>
LCD_BED_LEVELING        = build_src_filter=+<src/lcd/menu/menu_bed_leveling.cpp>
HAS_MENU_CANCELOBJECT   = build_src_filter=+<src/lcd/menu/menu_cancelobject.cpp>
HAS_MENU_DELTA_CALIBRATE = build_src_filter=+<src/lcd/menu/menu_delta_calibrate.cpp>
HAS_MENU_FILAMENT       = build_src_filter=+<src/lcd/menu/menu_filament.cpp>
LCD_INFO_MENU           = build_src_filter=+<src/lcd/menu/menu_info.cpp>
HAS_MENU_JOB_RECOVERY   = build_src_filter=+<src/lcd/menu/menu_job_recovery.cpp>
HAS_MENU_LED            = build_src_filter=+<src/lcd/menu/menu_led.cpp>
HAS_MENU_MEDIA          = build_src_filter=+<src/lcd/menu/menu_media.cpp>
HAS_MENU_MIXER          = build_src_filter=+<src/lcd/menu/menu_mixer.cpp>
HAS_MENU_MMU2           = build_src_filter=+<src/lcd/menu/menu_mmu2.cpp>
HAS_MENU_PASSWORD       = build_src_filter=+<src/lcd/menu/menu_password.cpp>
HAS_MENU_POWER_MONITOR  = build_src_filter=+<src/lcd/menu/menu_power_monitor.cpp>
HAS_MENU_CUTTER         = build_src_filter=+<src/lcd/menu/menu_spindle_laser.cpp>
HAS_MENU_TEMPERATURE    = build_src_filter=+<src/lcd/menu/menu_temperature.cpp>
HAS_MENU_TMC            = build_src_filter=+<src/lcd/menu/menu_tmc.cpp>
HAS_MENU_TOUCH_SCREEN   = build_src_filter=+<src/lcd/menu/menu_touch_screen.cpp>
HAS_MENU_UBL            = build_src_filter=+<src/lcd/menu/menu_ubl.cpp>
ANYCUBIC_LCD_I3MEGA     = build_src_filter=+<src/lcd/extui/lib/anycubic_i3mega>
HAS_DGUS_LCD            = build_src_filter=+<src/lcd/extui/lib/dgus> +<src/lcd/extui/dgus_lcd.cpp>
TOUCH_UI_FTDI_EVE       = build_src_filter=+<src/lcd/extui/lib/ftdi_eve_touch_ui>
HAS_ANYCUBIC_TFT_EXTUI  = build_src_filter=+<src/lcd/extui/anycubic_tft.cpp>
EXTUI_EXAMPLE           = build_src_filter=+<src/lcd/extui/example.cpp>
MALYAN_LCD              = build_src_filter=+<src/lcd/extui/malyan_lcd.cpp>
HAS_SPI_LCD             = build_src_filter=+<src/lcd/lcdprint.cpp>
USB_FLASH_DRIVE_SUPPORT = build_src_filter=+<src/sd/usb_flashdrive>
AUTO_BED_LEVELING_BILINEAR = build_src_filter=+<src/feature/bedlevel/abl>
AUTO_BED_LEVELING_(3POINT|(BI)?LINEAR) = build_src_filter=+<src/gcode/bedlevel/abl>
MESH_BED_LEVELING       = build_src_filter=+<src/feature/bedlevel/mbl> +<src/gcode/bedlevel/mbl>
AUTO_BED_LEVELING_UBL   = build_src_filter=+<src/feature/bedlevel/ubl> +<src/gcode/bedlevel/ubl>
BACKLASH_COMPENSATION   = build_src_filter=+<src/feature/backlash.cpp>
BARICUDA                = build_src_filter=+<src/feature/baricuda.cpp> +<src/gcode/feature/baricuda>
BINARY_FILE_TRANSFER    = build_src_filter=+<src/feature/binary_stream.cpp> +<src/libs/heatshrink>
BLTOUCH                 = build_src_filter=+<src/feature/bltouch.cpp>
CANCEL_OBJECTS          = build_src_filter=+<src/feature/cancel_object.cpp> +<src/gcode/feature/cancel>
CASE_LIGHT_ENABLE       = build_src_filter=+<src/feature/caselight> +<src/gcode/feature/caselight>
EXTERNAL_CLOSED_LOOP_CONTROLLER = build_src_filter=+<src/feature/closedloop.cpp> +<src/gcode/calibrate/M12.cpp>
USE_CONTROLLER_FAN      = build_src_filter=+<src/feature/controllerfan.cpp>
DAC_STEPPER_CURRENT     = build_src_filter=+<src/feature/dac>
DIRECT_STEPPING         = build_src_filter=+<src/feature/direct_stepping.cpp> +<src/gcode/motion/G6.cpp>
EMERGENCY_PARSER        = build_src_filter=+<src/feature/e_parser.cpp> -<src/gcode/control/M108_*.cpp>
I2C_POSITION_ENCODERS   = build_src_filter=+<src/feature/encoder_i2c.cpp>
HAS_FANMUX              = build_src_filter=+<src/feature/fanmux.cpp>
FILAMENT_WIDTH_SENSOR   = build_src_filter=+<src/feature/filwidth.cpp> +<src/gcode/feature/filwidth>
FWRETRACT               = build_src_filter=+<src/feature/fwretract.cpp> +<src/gcode/feature/fwretract>
HOST_ACTION_COMMANDS    = build_src_filter=+<src/feature/host_actions.cpp>
HOTEND_IDLE_TIMEOUT     = build_src_filter=+<src/feature/hotend_idle.cpp>
JOYSTICK                = build_src_filter=+<src/feature/joystick.cpp>
BLINKM                  = build_src_filter=+<src/feature/leds/blinkm.cpp>
HAS_COLOR_LEDS          = build_src_filter=+<src/feature/leds/leds.cpp> +<src/gcode/feature/leds/M150.cpp>
PCA9533                 = build_src_filter=+<src/feature/leds/pca9533.cpp>
PCA9632                 = build_src_filter=+<src/feature/leds/pca9632.cpp>
PRINTER_EVENT_LEDS      = build_src_filter=+<src/feature/leds/printer_event_leds.cpp>
TEMP_STAT_LEDS          = build_src_filter=+<src/feature/leds/tempstat.cpp>
MAX7219_DEBUG           = build_src_filter=+<src/feature/max7219.cpp> +<src/gcode/feature/leds/M7219.cpp>
MIXING_EXTRUDER         = build_src_filter=+<src/feature/mixing.cpp> +<src/gcode/feature/mixing/M163-M165.cpp>
PRUSA_MMU2              = build_src_filter=+<src/feature/mmu2> +<src/gcode/feature/prusa_MMU2>
PASSWORD_FEATURE        = build_src_filter=+<src/feature/password> +<src/gcode/feature/password>
ADVANCED_PAUSE_FEATURE  = build_src_filter=+<src/feature/pause.cpp> +<src/gcode/feature/pause/M600.cpp> +<src/gcode/feature/pause/M603.cpp>
AUTO_POWER_CONTROL      = build_src_filter=+<src/feature/power.cpp>
HAS_POWER_MONITOR       = build_src_filter=+<src/feature/power_monitor.cpp> +<src/gcode/feature/power_monitor>
POWER_LOSS_RECOVERY     = build_src_filter=+<src/feature/powerloss.cpp> +<src/gcode/feature/powerloss>
PROBE_TEMP_COMPENSATION = build_src_filter=+<src/feature/probe_temp_comp.cpp> +<src/gcode/calibrate/G76_M871.cpp>
HAS_FILAMENT_SENSOR     = build_src_filter=+<src/feature/runout.cpp> +<src/gcode/feature/runout>
MK2_MULTIPLEXER         = build_src_filter=+<src/feature/snmm.cpp>
EXT_SOLENOID|MANUAL_SOLENOID_CONTROL = build_src_filter=+<src/feature/solenoid.cpp>
HAS_CUTTER              = build_src_filter=+<src/feature/spindle_laser.cpp> +<src/gcode/control/M3-M5.cpp>
EXPERIMENTAL_I2CBUS     = build_src_filter=+<src/feature/twibus.cpp> +<src/gcode/feature/i2c>
Z_STEPPER_AUTO_ALIGN    = build_src_filter=+<src/feature/z_stepper_align.cpp> +<src/gcode/calibrate/G34_M422.cpp>
G26_MESH_VALIDATION     = build_src_filter=+<src/gcode/bedlevel/G26.cpp>
ASSISTED_TRAMMING       = build_src_filter=+<src/gcode/bedlevel/G35.cpp>
HAS_MESH                = build_src_filter=+<src/gcode/bedlevel/G42.cpp>
HAS_LEVELING            = build_src_filter=+<src/gcode/bedlevel/M420.cpp>
DELTA_AUTO_CALIBRATION  = build_src_filter=+<src/gcode/calibrate/G33.cpp>
CALIBRATION_GCODE       = build_src_filter=+<src/gcode/calibrate/G425.cpp>
Z_MIN_PROBE_REPEATABILITY_TEST = build_src_filter=+<src/gcode/calibrate/M48.cpp>
M100_FREE_MEMORY_WATCHER = build_src_filter=+<src/gcode/calibrate/M100.cpp>
BACKLASH_GCODE          = build_src_filter=+<src/gcode/calibrate/M425.cpp>
IS_KINEMATIC            = build_src_filter=+<src/gcode/calibrate/M665.cpp>
HAS_EXTRA_ENDSTOPS      = build_src_filter=+<src/gcode/calibrate/M666.cpp>
SKEW_CORRECTION_GCODE   = build_src_filter=+<src/gcode/calibrate/M852.cpp>
PINS_DEBUGGING          = build_src_filter=-<src/gcode/config/M43.cpp>
NO_VOLUMETRICS          = build_src_filter=-<src/gcode/config/M200-M205.cpp>
HAS_MULTI_EXTRUDER      = build_src_filter=+<src/gcode/config/M217.cpp>
HAS_HOTEND_OFFSET       = build_src_filter=+<src/gcode/config/M218.cpp>
EDITABLE_SERVO_ANGLES   = build_src_filter=+<src/gcode/config/M281.cpp>
PREVENT_COLD_EXTRUSION  = build_src_filter=+<src/gcode/config/M302.cpp>
HAS_USER_THERMISTORS    = build_src_filter=+<src/gcode/config/M305.cpp>
SD_ABORT_ON_ENDSTOP_HIT = build_src_filter=+<src/gcode/config/M540.cpp>
COOLANT_CONTROL         = build_src_filter=+<src/gcode/control/M7-M9.cpp>
HAS_SOFTWARE_ENDSTOPS   = build_src_filter=+<src/gcode/control/M211.cpp>
HAS_DUPLICATION_MODE    = build_src_filter=+<src/gcode/control/M605.cpp>
LIN_ADVANCE             = build_src_filter=+<src/gcode/feature/advance>
PHOTO_GCODE             = build_src_filter=+<src/gcode/feature/camera>
CONTROLLER_FAN_EDITABLE = build_src_filter=+<src/gcode/feature/controllerfan>
GCODE_MACROS            = build_src_filter=+<src/gcode/feature/macro>
GRADIENT_MIX            = build_src_filter=+<src/gcode/feature/mixing/M166.cpp>
HAS_SAVED_POSITIONS     = build_src_filter=+<src/gcode/feature/pause/G60.cpp> +<src/gcode/feature/pause/G61.cpp>
PARK_HEAD_ON_PAUSE      = build_src_filter=+<src/gcode/feature/pause/M125.cpp>
FILAMENT_LOAD_UNLOAD_GCODES = build_src_filter=+<src/gcode/feature/pause/M701_M702.cpp>
CNC_WORKSPACE_PLANES    = build_src_filter=+<src/gcode/geometry/G17-G19.cpp>
CNC_COORDINATE_SYSTEMS  = build_src_filter=+<src/gcode/geometry/G53-G59.cpp>
HAS_M206_COMMAND        = build_src_filter=+<src/gcode/geometry/M206_M428.cpp>
EXPECTED_PRINTER_CHECK  = build_src_filter=+<src/gcode/host/M16.cpp>
HOST_KEEPALIVE_FEATURE  = build_src_filter=+<src/gcode/host/M113.cpp>
REPETIER_GCODE_M360     = build_src_filter=+<src/gcode/host/M360.cpp>
HAS_GCODE_M876          = build_src_filter=+<src/gcode/host/M876.cpp>
HAS_RESUME_CONTINUE     = build_src_filter=+<src/gcode/lcd/M0_M1.cpp>
HAS_PREHEAT_COUNT       = build_src_filter=+<src/gcode/lcd/M145.cpp>
HAS_LCD_CONTRAST        = build_src_filter=+<src/gcode/lcd/M250.cpp>
LCD_SET_PROGRESS_MANUALLY = build_src_filter=+<src/gcode/lcd/M73.cpp>
TOUCH_SCREEN_CALIBRATION = build_src_filter=+<src/gcode/lcd/M995.cpp>
ARC_SUPPORT             = build_src_filter=+<src/gcode/motion/G2_G3.cpp>
GCODE_MOTION_MODES      = build_src_filter=+<src/gcode/motion/G80.cpp>
BABYSTEPPING            = build_src_filter=+<src/gcode/motion/M290.cpp>
Z_PROBE_SLED            = build_src_filter=+<src/gcode/probe/G31_G32.cpp>
G38_PROBE_TARGET        = build_src_filter=+<src/gcode/probe/G38.cpp>
MAGNETIC_PARKING_EXTRUDER = build_src_filter=+<src/gcode/probe/M951.cpp>
SDSUPPORT               = build_src_filter=+<src/gcode/sd>
HAS_EXTRUDERS           = build_src_filter=+<src/gcode/temp/M104_M109.cpp> +<src/gcode/config/M221.cpp>
INCH_MODE_SUPPORT       = build_src_filter=+<src/gcode/units/G20_G21.cpp>
TEMPERATURE_UNITS_SUPPORT = build_src_filter=+<src/gcode/units/M149.cpp>
NEED_HEX_PRINT          = build_src_filter=+<src/libs/hex_print.cpp>
NEED_LSF                = build_src_filter=+<src/libs/least_squares_fit.cpp>
NOZZLE_PARK_FEATURE     = build_src_filter=+<src/libs/nozzle.cpp> +<src/gcode/feature/pause/G27.cpp>
NOZZLE_CLEAN_FEATURE    = build_src_filter=+<src/libs/nozzle.cpp> +<src/gcode/feature/clean>
DELTA                   = build_src_filter=+<src/module/delta.cpp> +<src/gcode/calibrate/M666.cpp>
BEZIER_CURVE_SUPPORT    = build_src_filter=+<src/module/planner_bezier.cpp> +<src/gcode/motion/G5.cpp>
PRINTCOUNTER            = build_src_filter=+<src/module/printcounter.cpp>
HAS_BED_PROBE           = build_src_filter=+<src/module/probe.cpp> +<src/gcode/probe/G30.cpp> +<src/gcode/probe/M401_M402.cpp> +<src/gcode/probe/M851.cpp>
IS_SCARA                = build_src_filter=+<src/module/scara.cpp>
MORGAN_SCARA            = build_src_filter=+<src/gcode/scara>
(ESP3D_)?WIFISUPPORT    = AsyncTCP, ESP Async WebServer
  ESP3DLib=github¨dotcom/luc-github/ESP3DLib.git
  arduinoWebSockets=github¨dotcom/Links2004/arduinoWebSockets.git
  ESP32SSDP=github¨dotcom/luc-github/ESP32SSDP.git
  lib_ignore=ESPAsyncTCP
# Default values apply to all 'env:' prefixed environments
[env]
framework     = arduino
extra_scripts = ${common.extra_scripts}
build_flags   = ${common.build_flags}
lib_deps      = ${common.lib_deps}
monitor_speed = 250000
monitor_eol = LF
monitor_echo = yes
monitor_filters =
   colorize
   time
