I get this error when using sdfat library and teensy audio library:
Error:
In file included from C:\Users\E\.platformio\packages\framework-arduinoteensy\libraries\Audio/Audio.h:127:0,
from include/AudioSystem.h:5,
from src\AudioSystem.cpp:1:
C:\Users\E\.platformio\packages\framework-arduinoteensy\libraries\Audio/play_sd_raw.h:46:2: error: 'File' does not name a type
File rawfile;
In file included from C:\Users\E\.platformio\packages\framework-arduinoteensy\libraries\Audio/Audio.h:128:0,
C:\Users\E\.platformio\packages\framework-arduinoteensy\libraries\Audio/play_sd_wav.h:49:2: error: 'File' does not name a type
File wavfile;
Compiling .pio\build\teensy41\lib179\SerialFlash\SerialFlashDirectory.cpp.o
from src\main.cpp:10:
File rawfile;
File wavfile;
*** [.pio\build\teensy41\src\AudioSystem.cpp.o] Error 1
*** [.pio\build\teensy41\src\main.cpp.o] Error 1
but it works when i only use the sdfat library or audio library standalone.
main.cpp
#include "Arduino.h"
#include "SPI.h"
#include "Display.h"
Display display;
#include "Encoders.h"
Encoders encoders;
#include "Sd.h"
Sd sd;
#include "AudioSystem.h"
AudioSystem audio;
void setup()
audio.begin();
display.begin();
sd.begin();
encoders.begin();
void loop()
encoders.value();
encoders.button();
Audio.cpp
#include <AudioSystem.h>
// GUItool: begin automatically generated code
AudioSynthWaveform waveform1; // xy=427,319
AudioSynthWaveform waveform2; // xy=429,364
AudioSynthWaveformModulated waveformMod1; // xy=684,318
AudioOutputI2S i2s1; // xy=1000,323
AudioConnection patchCord1(waveform1, 0, waveformMod1, 0);
AudioConnection patchCord2(waveform2, 0, waveformMod1, 1);
AudioConnection patchCord3(waveformMod1, 0, i2s1, 0);
AudioConnection patchCord4(waveformMod1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1;
// GUItool: end automatically generated code
void myControlChange(byte channel, byte control, byte value);
void AudioSystem::begin()
AudioMemory(20);
usbMIDI.setHandleControlChange(myControlChange);
sgtl5000_1.enable();
sgtl5000_1.volume(0.32);
switch (control)
case 100:
waveform1.frequency(((float)value / 127));
break;
case 101:
waveform2.frequency(((float)value / 127));
break;
AudioSystem.h
#ifndef AUDIO_H
#define AUDIO_H
#include <Audio.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <SerialFlash.h>
#include <MIDIUSB.h>
#include <MIDI.h>
extern void myControlChange(byte channel, byte control, byte value);
class AudioSystem
public:
void begin();
Sd.cpp
#include "Sd.h"
// SD_FAT_TYPE = 0 for SdFat/File as defined in SdFatConfig.h,
// 1 for FAT16/FAT32, 2 for exFAT, 3 for FAT16/FAT32 and exFAT.
#define SD_FAT_TYPE 2
Change the value of SD_CS_PIN if you are using SPI and
your hardware does not use the default value, SS.
Common values are:
Arduino Ethernet shield: pin 4
Sparkfun SD shield: pin 8
Adafruit SD shields and modules: pin 10
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = SS;
#else // SDCARD_SS_PIN
// Assume built-in SD is used.
const uint8_t SD_CS_PIN = SDCARD_SS_PIN;
#endif // SDCARD_SS_PIN
// Try max SPI clock for an SD. Reduce SPI_CLOCK if errors occur.
#define SPI_CLOCK SD_SCK_MHZ(200)
// Try to select the best SD card configuration.
#if HAS_SDIO_CLASS
#define SD_CONFIG SdioConfig(FIFO_SDIO)
#elif ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SPI_CLOCK)
#else // HAS_SDIO_CLASS
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SPI_CLOCK)
#endif // HAS_SDIO_CLASS
#if SD_FAT_TYPE == 2
SdExFat sd;
ExFile file;
#else // SD_FAT_TYPE
#error Invalid SD_FAT_TYPE
#endif // SD_FAT_TYPE
// Serial print stream
ArduinoOutStream cout(Serial);
// store error strings in flash to save RAM
#define error(s) sd.errorHalt(&Serial, F(s))
void Sd::begin()
if (!sd.begin(SD_CONFIG))
sd.initErrorHalt(&Serial);
return;
Serial.println("sd succes");
AudioSystem.h
#ifndef AUDIO_H
#define AUDIO_H
#include <Audio.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <MIDI.h>
class AudioSystem
public:
void begin();
Sd.h
#ifndef Sd_H
#define Sd_H
#include "SPI.h"
#include "SdFat.h"
#include "sdios.h"
class Sd
public:
void begin();
