Hi Everyone!
I’m trying to build some code for stm32 using the arduino framework (stm32duino). I want to specify the version of this framework, and I don’t want to use the latest one (because they changed some interfaces in the latest one and unfortunately I don’t have time to update my code). The latest tag is 1.9.0 and I want to use 1.8.0 instead.
Here is the part of my platformio.ini:
[env:bluepill_f103c8_128k]
platform = ststm32
board = bluepill_f103c8_128k
platform_packages =
framework-arduinoststm32@https://github.com/stm32duino/Arduino_Core_STM32#1.8.0
This approach worked previosly but now it doesn’t work. Here is the output of pio run --verbose
Processing bluepill_f103c8_128k (platform: ststm32; board: bluepill_f103c8_128k; framework: arduino; platform_packages: framework-arduinoststm32@https://github.com/stm32duino/Arduino_Core_STM32#1.8.0; build_flags: -D USBD_USE_CDC, -D USBCON, -D USBD_VID=0x0483, -D USB_PRODUCT="\"MyDevice\"")
Tool Manager: Installing git+https://github.com/stm32duino/Arduino_Core_STM32#1.8.0
git version 2.21.0.windows.1
Cloning into 'C:\Users\Anton\.platformio\.cache\tmp\pkg-installing-k6wfdv7n'...
remote: Enumerating objects: 4524, done.
remote: Counting objects: 100% (4524/4524), done.
remote: Compressing objects: 100% (2951/2951), done.
remote: Total 4524 (delta 3036), reused 2331 (delta 1479), pack-reused 0
Receiving objects: 100% (4524/4524), 13.39 MiB | 3.90 MiB/s, done.
Resolving deltas: 100% (3036/3036), done.
Note: checking out '16f3644e7b9f8225dcb01f48bd857bdc3a978580'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
Checking out files: 100% (4177/4177), done.
Error: Could not find one of 'package.json' manifest files in the package
Output of pio --version
PlatformIO, version 5.0.0
Please help me Even some ideas on how to debug this problem would be helpful.
