When PIO_FRAMEWORK_MBED_RTOS_PRESENT defined in platformio.ini, I can’t build project. Without this flag build run successfull.
I need rtos features to use queues and osDelay.
Environment:
OS: Windows 10 1903 x64
PIO version: 4.0.3 and 4.1.0rc1
Python version: 3.8
PIO Core path: c:\pio
No, project path was c:\src\nrf52pio\, and sources was in c:\src\nrf52pio\src.
I’ve tried again after reboot, with c:\testproject, and got the same result.
Build log:
longcmd:
If I use ststm32 board disco_f303vc, pio run works just fine (but it uses framework-mbed@5.51401.191023 instead of framework-mbed@5.51304.190826 in nordicnrf52)
UPD:
Just tried this case with platformio installed in python2.7 virtualenv - error reproduces.
UPD2:
Python 3.6 x64, pio 4.0.3 on another Windows 10 x64 box and the same errors.
After hours of debugging build scripts, compiling gcc with -g, recompiling it with -O0 -g3, debugging gcc with gdb and analyzing build logs I’ve found the problem.
When platformio (actually scons) run arm-none-eabi-gcc.exe, it pass include parameters via @longcmd-xxx.txt file (to get around 32kb char command line limit in Windows), but gcc for some reason invokes cc1.exe without command-line file - just with process args. For nrf52 with PIO_FRAMEWORK_MBED_RTOS_PRESENT defined there are lot of defines and includes (more than for stm32, about 35kb vs 25kb), so executing cc1.exe leads to arm-none-eabi-gcc: error: CreateProcess: No such file or directory .
The actual command line for cc1 (or cc1plus in case of g++) can be obtained when adding -v to build_flags and running pio run -v.
As a workaround for now, I use .mbedignore files to minimize gcc commands (and build time). One in packages\framework-mbed\components\802.15.4_RF\ with * in it, and another in packages\framework-mbed\features\ with the following content:
