my code is fine yesterday, but today when i try to upload some errors show up, i don’t change anything in my code, i try to create a fresh project but i had the same problem it always error when i add library in platform.io file
my platformio.ini
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
https://github.com/me-no-dev/ESPAsyncWebServer.git
https://github.com/idkq/ESPConnect.git
miguelbalboa/MFRC522 @ ^1.4.10
marcoschwartz/LiquidCrystal_I2C @ ^1.1.4
milesburton/DallasTemperature @ ^3.11.0
paulstoffregen/OneWire @ ^2.3.
marvinroger/AsyncMqttClient @ ^0.9.0
The errors
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/__main__.py", line 102, in main
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1130, in __call__
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/cli.py", line 71, in invoke
return super().invoke(ctx)
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1657, in invoke
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 1404, in invoke
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/click/core.py", line 760, in invoke
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/click/decorators.py", line 26, in new_func
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/run/cli.py", line 144, in cli
process_env(
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/run/cli.py", line 201, in process_env
result = {"env": name, "duration": time(), "succeeded": ep.process()}
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/run/processor.py", line 83, in process
install_project_env_dependencies(
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/package/commands/install.py", line 132, in install_project_env_dependencies
_install_project_env_libraries(project_env, options),
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/package/commands/install.py", line 241, in _install_project_env_libraries
spec = PackageSpec(library)
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/package/meta.py", line 184, in __init__
self._parse(self.raw)
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/package/meta.py", line 291, in _parse
raw = parser(raw)
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/package/meta.py", line 316, in _parse_requirements
self.requirements = tokens[1].strip()
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/platformio/package/meta.py", line 231, in requirements
else semantic_version.SimpleSpec(str(value))
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/semantic_version/base.py", line 647, in __init__
self.clause = self._parse_to_clause(expression)
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/semantic_version/base.py", line 1043, in _parse_to_clause
return cls.Parser.parse(expression)
File "/home/iot-dev/.platformio/penv/lib/python3.10/site-packages/semantic_version/base.py", line 1063, in parse
raise ValueError("Invalid simple block %r" % block)
ValueError: Invalid simple block '^2.3.'
`pip install -U platformio` command
