Hello, I can’t publish my library to the PIO registry. This is what I’ve done following the docs:
First I run:
pio package publish
The command returned successfully. See the output:
Preparing a package...
Type: library
Owner: asl
Version: 0.1.2
Are you sure you want to publish the library asl/IoTeX-blockchain-client@0.1.2 to the registry?
[y/N]: y
The package has been accepted. We will notify you on email when process it.
But then I received an email with the following. The library has not been published, but there are no errors:
Hi asl!
We could not process your submitted package at 2021-12-02 12:37:35 from 94.13.220.17 with SHA-256 (c25ea96b61f399f009c77beadcd167348af44d93048359136e279deafdce4c13) due to the next issue:
None
