error on compiling I just can’t get any further because I don’t know where the error is
> Executing task: C:\Users\Heiko.platformio\penv\Scripts\platformio.exe run <
Can not remove temporary directory C:\Users\Heiko\Downloads\ESP32-Paxcounter-master.pio\build. Please remove it manually to avoid build issues
Processing usb (framework: arduino; board: esp32dev; platform: espressif32@3.3.0)
Parsing hardware configuration from C:\Users\Heiko\Downloads\ESP32-Paxcounter-master\src\hal\ttgobeam10.h
Parsing LMIC configuration from C:\Users\Heiko\Downloads\ESP32-Paxcounter-master\src\lmic_config.h
Parsing LORAWAN keys from C:\Users\Heiko\Downloads\ESP32-Paxcounter-master\src\loraconf.h
Parsing OTA keys from C:\Users\Heiko\Downloads\ESP32-Paxcounter-master\src\ota.conf
Target board: ttgo-t-beam @ 921600bps
Partition table: min_spiffs.csv
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/ttgo-t-beam.html
PLATFORM: Espressif 32 (3.3.0) > TTGO T-Beam
HARDWARE: ESP32 240MHz, 1.25MB RAM, 4MB Flash
framework-arduinoespressif32 3.10006.210326 (1.0.6)
tool-esptoolpy 1.30100.210531 (3.1.0)
tool-openocd-esp32 2.1000.20210721 (10.0)
toolchain-xtensa32 2.50200.97 (5.2.0)
LDF Modes: Finder ~ deep, Compatibility ~ soft
Library Manager: Installing git+https://github.com/SukkoPera/Arduino-Rokkit-Hash.git
FileNotFoundError: [WinError 2] Das System kann die angegebene Datei nicht finden:
File "C:\Users\Heiko.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 177:
File "C:\Users\Heiko.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 591:
File "C:\Users\Heiko.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 280:
File "C:\Users\Heiko.platformio\platforms\espressif32\builder\main.py", line 228:
File "C:\Users\Heiko.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Util.py", line 658:
File "C:\Users\Heiko.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 62:
env.ProcessProjectDeps()
File "C:\Users\Heiko.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 140:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "C:\Users\Heiko.platformio\penv\Lib\site-packages\platformio\builder\tools\piolib.py", line 1062:
project.install_dependencies()
File "C:\Users\Heiko.platformio\penv\Lib\site-packages\platformio\builder\tools\piolib.py", line 898:
lm.install(spec)
File "C:\Users\Heiko.platformio\penv\lib\site-packages\platformio\package\manager_install.py", line 48:
pkg = self._install(
File "C:\Users\Heiko.platformio\penv\lib\site-packages\platformio\package\manager\library.py", line 81:
return super(LibraryPackageManager, self).install(
File "C:\Users\Heiko.platformio\penv\lib\site-packages\platformio\package\manager_install.py", line 97:
pkg = self.install_from_url(spec.url, spec, silent=silent)
File "C:\Users\Heiko.platformio\penv\lib\site-packages\platformio\package\manager_install.py", line 141:
vcs = VCSClientFactory.new(tmp_dir, url)
File "C:\Users\Heiko.platformio\penv\lib\site-packages\platformio\package\vcsclient.py", line 54:
obj = getattr(sys.modules[name], "%sClient" % type.title())(
File "C:\Users\Heiko.platformio\penv\lib\site-packages\platformio\package\vcsclient.py", line 137:
self.configure()
File "C:\Users\Heiko.platformio\penv\lib\site-packages\platformio\package\vcsclient.py", line 146:
result = proc.exec_command([cls.command, "--exec-path"])
File "C:\Users\Heiko.platformio\penv\lib\site-packages\platformio\proc.py", line 117:
p = subprocess.Popen(*args, **kwargs)
File "C:\Users\Heiko.platformio\python3\lib\subprocess.py", line 951:
self._execute_child(args, executable, preexec_fn, close_fds,
File "C:\Users\Heiko.platformio\python3\lib\subprocess.py", line 1420:
hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
============================================================================= [FAILED] Took 1.97 seconds =============================================================================
Environment Status Duration
usb FAILED 00:00:01.966
======================================================================= 1 failed, 0 succeeded in 00:00:01.966 =======================================================================
The terminal process “C:\Users\Heiko.platformio\penv\Scripts\platformio.exe ‘run’” terminated with exit code: 1.
