Hello, I have problem with compilation this sample of code (or any code with SD card lib usage)
#include "SPI.h"
#include "SD.h"
#include "Wire.h"
#include "SdFat.h"
Serial.begin(9600);
File dataFile = SD.open("datalog.txt", FILE_WRITE);
if (dataFile) {
dataFile.println("arek");
dataFile.close();
Serial.println("arek");
else {
Serial.println("error opening datalog.txt");
delay(2000);
I get this error:
.pio/libdeps/nodemcuv2/SD/src/utility/Sd2PinMap.h:524:2: error: #error Architecture or board not supported.
My lib_deps looks like:
adafruit/Adafruit SSD1306@^2.5.1
adafruit/Adafruit GFX Library@^1.10.13
paulstoffregen/Time@^1.6.1
adafruit/Adafruit BusIO@^1.11.0
arduino-libraries/SD@^1.2.4
greiman/SdFat@^2.1.2
Output of console: https://www.toptal.com/developers/hastebin/lajohibepo.yaml
There problem also appears on original arduino ide, I’m using linux ubuntu 20.04
Please, help me
No, this is the Arduino (AVR) SD library.
You never declare libaries that are built into the framework via lib_deps
. As per Arduino/libraries at master · esp8266/Arduino · GitHub, the SD library is built into the Arduino-ESP8266 framework.
If I use your code with the platformio.ini
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
it already compiles successfully.
Linking .pio\build\nodemcuv2\firmware.elf
Retrieving maximum program size .pio\build\nodemcuv2\firmware.elf
Checking size .pio\build\nodemcuv2\firmware.elf
RAM: [=== ] 34.8% (used 28528 bytes from 81920 bytes)
Flash: [=== ] 28.6% (used 298881 bytes from 1044464 bytes)
Building .pio\build\nodemcuv2\firmware.bin
Creating BIN file ".pio\build\nodemcuv2\firmware.bin" using "C:\Users\Max\.platformio\packages\framework-arduinoespressif8266\bootloaders\eboot\eboot.elf" and ".pio\build\nodemcuv2\firmware.elf"
===================[SUCCESS] Took 19.67 seconds ===================
And as you can see in the project task Advanced → Verbose Build, the library is sourced from the framework folder.
|-- <SD> 2.0.0 (C:\Users\Max\.platformio\packages\framework-arduinoespressif8266\libraries\SD)
| |-- <SDFS> 0.1.0 (C:\Users\Max\.platformio\packages\framework-arduinoespressif8266\libraries\SDFS)
| | |-- <ESP8266SdFat> 2.0.2 (C:\Users\Max\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266SdFat)
So, just use the same platformio.ini
as I do and remove the .pio
folder of the project (downloaded libraries are stored in there) and recompile the project.
