I get error when compiling on board Feather M0. I’m at lost why it fails to build.
Compiling .pio/build/adafruit_feather_m0/src/BLESerial.cpp.o
Compiling .pio/build/adafruit_feather_m0/src/main.cpp.o
Compiling .pio/build/adafruit_feather_m0/lib3c1/Adafruit_TinyUSB_Arduino/arduino/Adafruit_TinyUSB_API.cpp.o
In file included from /home/ghil/.platformio/packages/framework-cmsis-atmel/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:262,
from /home/ghil/.platformio/packages/framework-cmsis-atmel/CMSIS/Device/ATMEL/samd21/include/samd21.h:69,
from /home/ghil/.platformio/packages/framework-cmsis-atmel/CMSIS/Device/ATMEL/samd.h:105,
from /home/ghil/.platformio/packages/framework-cmsis-atmel/CMSIS/Device/ATMEL/sam.h:565,
from /home/ghil/.platformio/packages/framework-arduino-samd-adafruit/cores/arduino/Arduino.h:48,
from .pio/libdeps/adafruit_feather_m0/Adafruit NeoPixel/Adafruit_NeoPixel.h:41,
from src/main.cpp:26:
/home/ghil/.platformio/packages/framework-cmsis-atmel/CMSIS/Device/ATMEL/samd21/include/component/mtb.h:363:8: error: declaration does not declare anything [-fpermissive]
363 | __IO MTB_MASTER_Type MASTER; /**< \brief Offset: 0x004 (R/W 32) MTB Master */
Here is the mtb.h part that’s causing the error. TIA
/** \brief MTB hardware registers */
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
typedef struct {
__IO MTB_POSITION_Type POSITION; /**< \brief Offset: 0x000 (R/W 32) MTB Position */
__IO MTB_FLOW_Type FLOW; /**< \brief Offset: 0x008 (R/W 32) MTB Flow */
__I MTB_BASE_Type BASE; /**< \brief Offset: 0x00C (R/ 32) MTB Base */
RoReg8 Reserved1[0xEF0];
__IO MTB_ITCTRL_Type ITCTRL; /**< \brief Offset: 0xF00 (R/W 32) MTB Integration Mode Control */
RoReg8 Reserved2[0x9C];
__IO MTB_CLAIMSET_Type CLAIMSET; /**< \brief Offset: 0xFA0 (R/W 32) MTB Claim Set */
__IO MTB_CLAIMCLR_Type CLAIMCLR; /**< \brief Offset: 0xFA4 (R/W 32) MTB Claim Clear */
RoReg8 Reserved3[0x8];
__IO MTB_LOCKACCESS_Type LOCKACCESS; /**< \brief Offset: 0xFB0 (R/W 32) MTB Lock Access */
__I MTB_LOCKSTATUS_Type LOCKSTATUS; /**< \brief Offset: 0xFB4 (R/ 32) MTB Lock Status */
__I MTB_AUTHSTATUS_Type AUTHSTATUS; /**< \brief Offset: 0xFB8 (R/ 32) MTB Authentication Status */
__I MTB_DEVARCH_Type DEVARCH; /**< \brief Offset: 0xFBC (R/ 32) MTB Device Architecture */
RoReg8 Reserved4[0x8];
__I MTB_DEVID_Type DEVID; /**< \brief Offset: 0xFC8 (R/ 32) MTB Device Configuration */
__I MTB_DEVTYPE_Type DEVTYPE; /**< \brief Offset: 0xFCC (R/ 32) MTB Device Type */
__I MTB_PID4_Type PID4; /**< \brief Offset: 0xFD0 (R/ 32) CoreSight */
__I MTB_PID5_Type PID5; /**< \brief Offset: 0xFD4 (R/ 32) CoreSight */
__I MTB_PID6_Type PID6; /**< \brief Offset: 0xFD8 (R/ 32) CoreSight */
__I MTB_PID7_Type PID7; /**< \brief Offset: 0xFDC (R/ 32) CoreSight */
__I MTB_PID0_Type PID0; /**< \brief Offset: 0xFE0 (R/ 32) CoreSight */
__I MTB_PID1_Type PID1; /**< \brief Offset: 0xFE4 (R/ 32) CoreSight */
__I MTB_PID2_Type PID2; /**< \brief Offset: 0xFE8 (R/ 32) CoreSight */
__I MTB_PID3_Type PID3; /**< \brief Offset: 0xFEC (R/ 32) CoreSight */
__I MTB_CID0_Type CID0; /**< \brief Offset: 0xFF0 (R/ 32) CoreSight */
__I MTB_CID1_Type CID1; /**< \brief Offset: 0xFF4 (R/ 32) CoreSight */
__I MTB_CID2_Type CID2; /**< \brief Offset: 0xFF8 (R/ 32) CoreSight */
__I MTB_CID3_Type CID3; /**< \brief Offset: 0xFFC (R/ 32) CoreSight */
} Mtb;
#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
