Hi all!
i’m getting this error compiling the project:
_Helloworld.ino:51:3: error: ‘QRCode’ was not declared in this scope.
Someone can give a bit of light? I’m stucked and can not understand why i get this error here…
Thanks very much in advance
The code is:
#include <arduino.h>
#include <SPI.h>
#include <qrcode.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>#define TFT_DC 2
#define TFT_CS 15
Adafruit_ILI9341 display = Adafruit_ILI9341(TFT_CS, TFT_DC);// change these to match your display’s resolution:
const int TFT_WIDTH = 220;
const int TFT_HEIGHT = 176;// colors for a color display:
const int backgroundColor = 0xFFFFFF; // white
const int foregroundColor = 0x000000; // blackvoid setup() {
// initialize serial:
Serial.begin(9600);
// when reading serial input set a 10ms timeout:
Serial.setTimeout(10);
// wait 3 sec. for serial monitor to open:
if (!Serial) delay(3000);
// start the display:
// initialize the display
display.begin();
// clear the screen:
// display.clear();
Serial.println(“Enter a text message to display:”);
}void loop() {
// if there’s a string in the serial buffer, display it.
// Then prompt for a message skip the rest of the loop:
if (Serial.available()) {
// otherwise, read the serial input and make a QR Code:
String incoming = Serial.readString();
displayQrCode(incoming);
void displayQrCode(String message) {
Serial.print("Message length: ");
Serial.println(message.length());// Create the QR code
QRCode qrcode;
// See table at GitHub - ricmoo/QRCode: QR code generation library in C, optimized for low-power devices, such as Arduino.
// or Information capacity and versions of QR Code | QRcode.com | DENSO WAVE for
// calculation of data capacity of a QR code. Current
// settings will get you about 100 bytes:
int qrVersion = 4;
// can be ECC_LOW, ECC_MEDIUM, ECC_QUARTILE and ECC_HIGH (0-3, respectively):
int qrErrorLevel = ECC_MEDIUM;// allocate QR code memory:
byte qrcodeBytes[qrcode_getBufferSize(qrVersion)];
qrcode_initText(&qrcode, qrcodeBytes, qrVersion, qrErrorLevel, message.c_str());// QR Code block characteristics will depend on the display:
// QR code needs a “quiet zone” of background color around it, hence the offset:
int offset = 10;
int blockSize = (TFT_HEIGHT - (offset * 2)) / qrcode.size;
// fill with the background color:
display.setBackgroundColor(backgroundColor);// read the bytes of the QR code and set the blocks light or dark, accordingly:
// vertical loop:
for (byte y = 0; y < qrcode.size; y++) {
// horizontal loop:
for (byte x = 0; x < qrcode.size; x++) {
// caculate the block’s X and Y positions:
int blockX = (x * blockSize) + offset;
int blockY = (y * blockSize) + offset;
// read the block value from the QRcode:
int blockValue = qrcode_getModule(&qrcode, x, y);
// set the default block color:
int blockColor = backgroundColor;
// if the block value is 1, set color to foreground color instead:
if (blockValue == 1) {
blockColor = foregroundColor;
// display the block on the screen:
display.fillRectangle(blockX, blockY,
blockX + blockSize, blockY + blockSize,
blockColor);
// display.println(“Scan me”);
// print the message and display it:
Serial.println(message);delay(10);
