I’m using this configuration in platform.ini:
[env:esp32cam]
board = esp32cam
platform_packages = framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git#2.0.7
Starting from version 2.0.7 I get the following error:
Resolving esp32cam dependencies…
Error! Failed to extract upstream toolchainconfigurations:
Bad package version esp-2021r2-patch5-8.4.0
You can disable this feature via the board_build.arduino.upstream_packages = no
setting in your platformio.ini
file.
