Erreur d'installation avec visual studio code pour marlin
File “C:\Users\andre.platformio.cache\tmp.piocore-installer-wa5i9nmc\tmp0k56og4j\pioinstaller.zip\pioinstaller\python.py”, line 199, in find_compatible_pythons
File “C:\Users\andre.platformio\python3\lib\subprocess.py”, line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “C:\Users\andre.platformio\python3\lib\subprocess.py”, line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '[‘C:\Users\andre\AppData\Local\Microsoft\WindowsApps\python3.exe’, ‘C:\Users\andre\.platformio\.cache\tmp\get-platformio-1.0.1.py’, '–no-shutdo…
merci de votre aide
Known error when Microsoft’s Python3 is in the PATH environment variable. See Failed to Install PlatformIO v2.3.0 on VS Code v1.54.3.
