I am trying to flash an Elegoo Nano V3 a Chinese clone of the Arduino nano based on a CH340 and an ATmega328P.
I am using Archlinux and with both the Arduino IDE and PlatformIO using the Arduino framework I do not succeed to flash the firmware.
The output is the following:
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
And my platformio.ini
configuration is the following:
[env:nanoatmega328]
board = nanoatmega328
upload_speed = 57600
I tried as well without specifying the upload_speed
but nothing changed.
Any idea?
Thank you in advance!
Martino
IIRC, you can get that error when trying to flash a 328p that has the new optiboot bootloader but you’re telling the upload tool (avrdude) that it has the older bootloader. Try changing your board to …
nanoatmega328new
… and remove the upload speed parameter (as it isn’t needed, and is wrong for the new bootloader anyway), and see if that cures it. This would be the same as using the ‘Tools → Processor’ option on the Arduino IDE to change between Atmega328P
and Atmega328P (Old Bootloader)
Hi @pfeerick,
I tried using the nanoatmega328new
as well as using the arduino ide with the ATmega328P
processor, however I did not improve the situation.
The avrdude output of the using the nanoatmega328new
option is one of the following (seems to alternate):
avrdude: stk500_getsync(): can't communicate with device: resp=0x90
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xfc
avrdude: stk500_initialize(): failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
I don’t know if it can help to find the problem!
Thank you in advance,
Martino
Are you sure you have removed the upload_speed
parameter?
Are you able to flash using the Arduino IDE? Can you show the settings there?
