hi, unfortunately I could not run this code because it gives me this error )"eeprom_dumpEeprom’ was not declared in this scope), could anyone help me what can I do? I need to do it ASA possible. I share my code here.
* DUCO - CORE
* The main script to parse any incoming cmds
boolean exec_executeBasicCommand(String &com)
boolean executed = true;
if (com.startsWith(CMD_CHANGELENGTH)) //C01 Move Pen To Point
exec_changeLength();
#ifdef VECTOR_LINES
else if (com.startsWith(CMD_CHANGELENGTHDIRECT)) // C17 draw a straight line
exec_changeLengthDirect();
else if (com.startsWith(CMD_SETMOTORSPEED)) //C31
exec_setMotorSpeed();
else if (com.startsWith(CMD_SETMOTORACCEL)) //C32
exec_setMotorAcceleration();
else if (com.startsWith(CMD_SETPOSITION)) //C09 SET HOME
exec_setPosition();
else if (com.startsWith(CMD_PENDOWN)) // C13 penDown
penlift_penDraw();
else if (com.startsWith(CMD_PENUP)) // C14 penUp
penlift_penRelease();
else if (com.startsWith(CMD_SETPENLIFTRANGE)) // C45
exec_setPenLiftRange();
else if (com.startsWith(CMD_SETMACHINESIZE)) // C24
exec_setMachineSizeFromCommand();
else if (com.startsWith(CMD_SETMACHINEMMPERREV))
exec_setMachineMmPerRevFromCommand();
else if (com.startsWith(CMD_SETMACHINESTEPSPERREV))
exec_setMachineStepsPerRevFromCommand();
else if (com.startsWith(CMD_GETMACHINEDETAILS))
exec_reportMachineSpec();
else if (com.startsWith(CMD_RESETEEPROM))
eeprom_resetEeprom();
// new added function
else if (com.startsWith(CMD_CHANGESPEEDMODE)) //C03
exec_setSpeedMode();
else if (com.startsWith(CMD_SWITCHPEN)) //C12
exec_setPenMode();
else if (com.startsWith(CMD_PLAROTATE))
exec_platRotate();
else if (com.startsWith(CMD_CHANGEMOTORMODE))
exec_setMotorMode();
else
executed = false; // no basic command is executed
return executed;
void exec_reportMachineSpec()
eeprom_dumpEeprom();
Serial.print(F("PGSIZE,")); // align with String.startsWith() in processing
Serial.print(machineWidth);
Serial.print(COMMA);
Serial.print(machineHeight);
Serial.println(CMD_END);
Serial.print(F("PGMMPERREV,"));
Serial.print(mmPerRev);
Serial.print(F("PGSTEPSPERREV,"));
Serial.print(motorStepsPerRev);
Serial.print(F("PGLIFT,"));
Serial.print(downPosition);
Serial.print(upPosition);
Serial.print(F("PGSPEED,"));
Serial.print(currentMaxSpeed);
if(usingAcceleration){
Serial.print(currentAcceleration);
Serial.print(F("SPEEDMATCH:"));
Serial.print(speedMatch? 1:0);
Serial.print(F("ACCEL:"));
Serial.print(usingAcceleration? 1:0);
Serial.print(F("PENMODE:"));
Serial.print(penMode);
/*--- accept new values from inParams, store them into EEPROM and also reload to global variables---*/
// C04 interleave/microstepping change
void exec_setMotorMode(){
byte motorMode = (byte) atoi(inParam1);
// motor._speed/_maxSpeed/_accel/_position will all be set to zero
if(motorMode != currentMotorMode){
if(motorMode==0){
motorA = AccelStepper(forwardaI, backwardaI);
motorB = AccelStepper(forwardbI, backwardbI);
Serial.println("Interleave choosen!");
if(motorMode==1){
motorA = AccelStepper(forwardaM, backwardaM);
motorB = AccelStepper(forwardbM, backwardbM);
Serial.println("Microstepping choosen!");
currentMotorMode = motorMode;
// don't know why these settings are needed
// but without them, stepper's speed is not controllable
// i.e. setSpeed doesn't work
motorA.setMaxSpeed(defaultMaxSpeed);
motorB.setMaxSpeed(defaultMaxSpeed);
motorA.setAcceleration(defaultMaxAcceleration);
motorB.setAcceleration(defaultMaxAcceleration);
// C03 speedmode change
void exec_setSpeedMode(){
byte speedSelector = (byte) atoi(inParam1);
EEPROM_writeAnything(EEPROM_SPEED_MODE,speedSelector);
eeprom_loadSpeedMode(); // reload
if(!usingAcceleration){
EEPROM_writeAnything(EEPROM_MACHINE_MOTOR_ACCEL, -1); // not used
eeprom_loadSpeed(); // reload speed and accel
// C11 for platform rotate
void exec_platRotate(){
int Selection = atoi(inParam1);
if(Selection<=3 && Selection>=1){
platformRotate(Selection);
else{
Serial.println("Selection not valid!");
// C12 pen switch
void exec_setPenMode(){
int mode = atoi(inParam1);
EEPROM_writeAnything(EEPROM_PEN_MODE,mode);
eeprom_loadPenMode(); //reload
switch(penMode){
case 0:
// reset to default
EEPROM_writeAnything(EEPROM_PENLIFT_DOWN,DEFAULT_DOWN_POSITION);
EEPROM_writeAnything(EEPROM_PENLIFT_UP,DEFAULT_UP_POSITION);
eeprom_loadPenUpPosition(); // reload
eeprom_loadPenDownPosition();//
break;
case 1:
EEPROM_writeAnything(EEPROM_PENLIFT_UP,-1); //not used
EEPROM_writeAnything(EEPROM_PENLIFT_DOWN,0); //set to lowest value
eeprom_loadPenDownPosition(); // reload
break;
case 2:
// need change along with different pen length/setup
EEPROM_writeAnything(EEPROM_PENLIFT_UP,1750);
dynamicDownPos = upPosition;
break;
default:
break;
// C24
void exec_setMachineSizeFromCommand()
int width = atoi(inParam1); // machine width
int height = atoi(inParam2); // machine height
// load to get current settings
int currentValue;
EEPROM_readAnything(EEPROM_MACHINE_WIDTH, currentValue);
if (currentValue != width)
if (width > 10)
EEPROM_writeAnything(EEPROM_MACHINE_WIDTH, width);
EEPROM_readAnything(EEPROM_MACHINE_HEIGHT, currentValue);
if (currentValue != height)
if (height > 10)
EEPROM_writeAnything(EEPROM_MACHINE_HEIGHT, height);
// reload
eeprom_loadMachineSize(); // load from EEPROM to global variables - machineWidth & machineHeight
void exec_setMachineMmPerRevFromCommand()
EEPROM_writeAnything(EEPROM_MACHINE_MM_PER_REV, (float)atof(inParam1));
eeprom_loadMachineSpecFromEeprom();
void exec_setMachineStepsPerRevFromCommand()
EEPROM_writeAnything(EEPROM_MACHINE_STEPS_PER_REV, atoi(inParam1));
void exec_setPenLiftRange()
// Laser Cutting mode
if (penMode==1 && inNoOfParams ==1){
exec_setLaserPower();
// Linear Actuation mode
if (penMode==0){
int down = atoi(inParam1);
int up = atoi(inParam2);
if (inNoOfParams == 3)
// 3 params (C45,<downpos>,<uppos>,1,END) means save values to EEPROM
EEPROM_writeAnything(EEPROM_PENLIFT_DOWN, down);
EEPROM_writeAnything(EEPROM_PENLIFT_UP, up);
else if (inNoOfParams == 2)
// 2 params (C45,<downpos>,<uppos>,END) means just do a range test
// first movePen to up postion
penlift_initial(up);
// then do the test
penlift_movePen(up, down, penLiftSpeed);
delay(200);
penlift_movePen(down, up, penLiftSpeed);
delay(200);
// Pen Force mode
if (penMode==2){
int low= atoi(inParam1);
int high = atoi(inParam2);
ResHig = high;
ResLow = low;
// test on new pressure
isPenUp = false;
penforce();
delay(1500); // delay some time
penlift_penUp(); // return to normal
// used in penMode:1
void exec_setLaserPower(){
int down = constrain(atoi(inParam1),0,100);
EEPROM_writeAnything(EEPROM_PENLIFT_DOWN,down);
Serial.print("set power to:");
Serial.println(downPosition);
//Single parameter to set max speed, add a second parameter of "1" to make it persist.
void exec_setMotorSpeed()
exec_setMotorSpeed((float)atof(inParam1));
if (inNoOfParams == 2 && atoi(inParam2) == 1) // second parameter appears as "1", store to EEPROM
EEPROM_writeAnything(EEPROM_MACHINE_MOTOR_SPEED, currentMaxSpeed);
void exec_setMotorSpeed(float speed)
currentMaxSpeed = speed;
Serial.print(F("New max speed: "));
Serial.println(currentMaxSpeed);
// Single parameter to set acceleration, add a second parameter of "1" to make it persist.
void exec_setMotorAcceleration()
exec_setMotorAcceleration((float)atof(inParam1));
EEPROM_writeAnything(EEPROM_MACHINE_MOTOR_ACCEL, currentAcceleration);
void exec_setMotorAcceleration(float accel)
currentAcceleration = accel;
Serial.print(F("New accel: "));
Serial.println(currentAcceleration);
// C09 SET HOME
// inParam1 and inParam2 are both absolute steps
void exec_setPosition()
long targetA = atol(inParam1);
long targetB = atol(inParam2);
motorA.setCurrentPosition(targetA); // set absolute position value
motorB.setCurrentPosition(targetB);
impl_engageMotors(); // do a brief test after SET HOME
reportPosition();
//store Home position
StartPosA = targetA;
StartPosB = targetB;
/* ------ depends on changeLength() which already takes care of speed/accel stuffs --------*/
// CO1 Move Pen to point not necessarily straight line
// inParam1 & inParam2 give target absolute position in steps
// adding functionality to return HOME
void exec_changeLength()
float lenA=(float)atof(inParam1);
float lenB=(float)atof(inParam2);
if(lenA<0 && lenB<0){
//return home when obtained "C01,-1,-1,END"
lenA = (float)StartPosA;
lenB = (float)StartPosB;
Serial.println("begin non-straight line moving!");
changeLength(lenA, lenB, currentMaxSpeed, currentMaxSpeed); // not straight line, run with max speed
#ifdef VECTOR_LINES
void exec_changeLengthDirect()
float endA = (float)atof(inParam1); // in steps
float endB = (float)atof(inParam2); // in steps
int maxSegmentLength = atoi(inParam3); // max length one time
float startA = motorA.currentPosition(); // in steps
float startB = motorB.currentPosition(); // in steps
if (endA < 20 || endB < 20 || endA > getMaxLength() || endB > getMaxLength())
Serial.print(MSG_E_STR);
Serial.println(F("This point falls outside the area of this machine. Skipping it."));
else
exec_drawBetweenPoints(startA, startB, endA, endB, maxSegmentLength);
// p1, p2 are represented as native coordinates
// moving between them should be direct!!!
void exec_drawBetweenPoints(float p1a, float p1b, float p2a, float p2b, int maxSegmentLength)
float c1x = getCartesianXFP(p1a, p1b);
float c1y = getCartesianYFP(c1x, p1a);
float c2x = getCartesianXFP(p2a, p2b);
float c2y = getCartesianYFP(c2x, p2a);
if (c2x > 20
&& c2x<pageWidth-20
&& c2y > 20
&& c2y <pageHeight-20
&& c1x > 20
&& c1x<pageWidth-20
&& c1y > 20
&& c1y <pageHeight-20
reportingPosition = false;
float deltaX = c2x-c1x; // distance each must move (signed)
float deltaY = c2y-c1y;
int linesegs = 1; // assume at least 1 line segment will get us there.
if (abs(deltaX) > abs(deltaY))
// slope <=1 case
while ((abs(deltaX)/linesegs) > maxSegmentLength)
linesegs++;
else
// slope >1 case
while ((abs(deltaY)/linesegs) > maxSegmentLength)
linesegs++;
// reduce delta to one line segments' worth.
deltaX = deltaX/linesegs;
deltaY = deltaY/linesegs;
// render the line in N shorter segments
long runSpeed = 0;
while (linesegs > 0)
c1x = c1x + deltaX;
c1y = c1y + deltaY;
// convert back to native coordinates
float pA = getMachineA(c1x, c1y);
float pB = getMachineB(c1x, c1y);
// do the move with speed control or not
runSpeed = desiredSpeed(linesegs, runSpeed, currentAcceleration*2);
else{
runSpeed = currentMaxSpeed;
// adding speed match for two steppers
// this function is under development!
// high speed stepper will compromise to lower one
// and line quality is not improved?
if(speedMatch){
float absRatio = speedRatioMatch(c1x-deltaX,c1y-deltaY,c1x,c1y);
if(absRatio>1){
changeLength(pA, pB, runSpeed, runSpeed/absRatio);
else{
changeLength(pA, pB, runSpeed*absRatio, runSpeed);
else{
changeLength(pA, pB, runSpeed, runSpeed);
// one line less to do!
linesegs--;
// reset back to "normal" operation
reportingPosition = true;
reportPosition();
else
Serial.println(F("Line is not on the page. Skipping it."));
