Hello
I’m new to programming and especially PlatformIO .
Installed above lib but get error easycat.h no such file in library.
Thought maybe I made wrong and searched and found :
PlatformIO lib install “EasyCAT_lib@47eefd8351”
and got Library Storage:
LibraryManager: Installing id=3502 @ 47eefd8351
EasyCAT_lib @ 47eefd8351 is already installed
Do I do something wrong or is there a problem (As I now believe :- ) with the lib.
What to do except using Arduino , where it works, is there a workaround ?
Bjorn
@ maxgerhardt
I’m sorry but I can’t find where i found a similar problem about no such file in directory.
My only excuse is that i’m 71 and forget many things these days.
Anyhow The problem was much deeper than mine but in the beginning you recommended to delete the lib and install it under lib… so I did that.
After some bastel (The guy who wrote it apparently used Arduino (nothing in the cpp file)
I at last got
SUCCESS
At the moment I can not test as I have no EasyCAT board right now.
But as it compiled I probably only have to change programming mistakes.
I still think the lib at PlatformIO has a glitch as the lib I installed had quite different errors and to a point understandable for me :- )
