This script is running. The buzzers still don’t work, but I’m going to look at the library.
I put the libraries into the /src folder, because they were no longer recognized when I reopened the file a few hours later.
Now this:
PLATFORM: Espressif 32 1.12.4 > Espressif ESP32 Dev Module
Looking for TimeLib library in registry
Warning! Library `{'name': 'TimeLib', 'requirements': None}` has not been found in PlatformIO Registry.
You can ignore this message, if `{'name': 'TimeLib', 'requirements': None}` is a built-in library (included in framework, SDK). E.g., SPI, Wire, etc.
Looking for Adafruit_SSD1306 library in registry
Warning! Library `{'name': 'Adafruit_SSD1306', 'requirements': None}` has not been found in PlatformIO Registry.
You can ignore this message, if `{'name': 'Adafruit_SSD1306', 'requirements': None}` is a built-in library (included in framework, SDK). E.g., SPI, Wire, etc.
Found 37 compatible libraries
|-- <Wire> 1.0.1
|-- <Tone32> 1.0.0
|-- <Adafruit GFX Library> 1.10.0
| |-- <Adafruit BusIO> 0.0.2
| | |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
|-- <Adafruit SSD1306> 2.3.1
| | | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
Compiling .pio\build\esp32dev\libd72\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
Compiling .pio\build\esp32dev\libd72\Adafruit GFX Library\Adafruit_MonoOLED.cpp.o
Compiling .pio\build\esp32dev\libd72\Adafruit GFX Library\Adafruit_SPITFT.cpp.o
Compiling .pio\build\esp32dev\libd72\Adafruit GFX Library\glcdfont.c.o
Compiling .pio\build\esp32dev\lib747\Adafruit SSD1306\Adafruit_SSD1306.cpp.o
In file included from lib\Adafruit GFX Library\Adafruit_GrayOLED.cpp:20:0:
lib\Adafruit GFX Library\Adafruit_GrayOLED.h:31:32: fatal error: Adafruit_SPIDevice.h: No such file or directory
* Looking for Adafruit_SPIDevice.h dependency? Check our library registry!
* CLI > platformio lib search "header:Adafruit_SPIDevice.h"
* Web > https://platformio.org/lib/search?query=header:Adafruit_SPIDevice.h
compilation terminated.
In file included from lib\Adafruit GFX Library\Adafruit_MonoOLED.cpp:20:0:
lib\Adafruit GFX Library\Adafruit_MonoOLED.h:31:32: fatal error: Adafruit_SPIDevice.h: No such file or directory
*** [.pio\build\esp32dev\libd72\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o] Error 1
*** [.pio\build\esp32dev\libd72\Adafruit GFX Library\Adafruit_MonoOLED.cpp.o] Error 1
=================================================== [FAILED] Took 4.74 seconds ===================================================
The terminal process "C:\Users\joema\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
> Executing task in folder Random_5_Buzz_OLED_R32: C:\Users\joema\.platformio\penv\Scripts\platformio.exe run <
Found 32 compatible libraries
|-- <Wire> 1.0.1
|-- <Tone32> 1.0.0
|-- <Adafruit BusIO> 1.4.1
| |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
|-- <SPI> 1.0
|-- <Adafruit SSD1306> 1.3.0
| | | |-- <Wire> 1.0.1
| | | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
Compiling .pio\build\esp32dev\src\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
Compiling .pio\build\esp32dev\src\Adafruit BusIO\Adafruit_I2CRegister.cpp.o
Compiling .pio\build\esp32dev\src\Adafruit GFX Library\Adafruit_GFX.cpp.o
Compiling .pio\build\esp32dev\src\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
src\Adafruit BusIO\Adafruit_I2CDevice.cpp:12:6: error: prototype for 'bool Adafruit_I2CDevice::begin()' does not match any in class 'Adafruit_I2CDevice'
bool Adafruit_I2CDevice::begin(void) {
In file included from src\Adafruit BusIO\Adafruit_I2CDevice.cpp:1:0:
C:\Users\joema\.platformio\lib\Adafruit BusIO/Adafruit_I2CDevice.h:11:8: error: candidate is: bool Adafruit_I2CDevice::begin(bool)
bool begin(bool addr_detect = true);
src\Adafruit BusIO\Adafruit_I2CDevice.cpp: In member function 'bool Adafruit_I2CDevice::read(uint8_t*, size_t, bool)':
src\Adafruit BusIO\Adafruit_I2CDevice.cpp:99:51: warning: ISO C++ says that these are ambiguous, even though the worst conversion
for the first is better than the worst conversion for the second:
if (_wire->requestFrom(_addr, (uint8_t)len, stop) != len) {
In file included from C:\Users\joema\.platformio\lib\Adafruit BusIO/Adafruit_I2CDevice.h:1:0,
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\Wire\src/Wire.h:98:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
uint8_t requestFrom(int address, int size, int sendStop);
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\Wire\src/Wire.h:96:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t, uint8_t)
uint8_t requestFrom(uint8_t address, uint8_t size, uint8_t sendStop);
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\Wire\src/Wire.h:94:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint16_t, uint8_t, uint8_t)
uint8_t requestFrom(uint16_t address, uint8_t size, uint8_t sendStop);
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\Wire\src/Wire.h:93:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint16_t, uint8_t, bool)
uint8_t requestFrom(uint16_t address, uint8_t size, bool sendStop);
*** [.pio\build\esp32dev\src\Adafruit BusIO\Adafruit_I2CDevice.cpp.o] Error 1
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:3:145: error: ISO C++ forbids declaration of 'Adafruit_I2CRegister' with no type [-fpermissive]
Adafruit_I2CRegister::Adafruit_I2CRegister(Adafruit_I2CDevice *device, uint16_t reg_addr, uint8_t width, uint8_t bitorder, uint8_t address_width) {
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:3:145: error: no 'int Adafruit_BusIO_Register::Adafruit_I2CRegister(Adafruit_I2CDevice*, uint16_t, uint8_t, uint8_t, uint8_t)' member function declared in class 'Adafruit_BusIO_Register'
src\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'bool Adafruit_BusIO_Register::write(uint8_t*, uint8_t)':
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:14:9: error: '_device' was not declared in this scope
if (! _device->write(buffer, len, true, addrbuffer, _addrwidth)) {
src\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'bool Adafruit_BusIO_Register::write(uint32_t, uint8_t)':
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:29:9: error: '_bitorder' was not declared in this scope
if (_bitorder == LSBFIRST) {
src\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'uint32_t Adafruit_BusIO_Register::read()':
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:49:10: error: '_bitorder' was not declared in this scope
src\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'bool Adafruit_BusIO_Register::read(uint8_t*, uint8_t)':
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:62:9: error: '_device' was not declared in this scope
if (! _device->write_then_read(_buffer, 1, buffer, len)) {
src\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'bool Adafruit_BusIO_Register::read(uint16_t*)':
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:73:7: error: '_bitorder' was not declared in this scope
src\Adafruit BusIO\Adafruit_I2CRegister.cpp: At global scope:
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:105:106: error: ISO C++ forbids declaration of 'Adafruit_I2CRegisterBits' with no type [-fpermissive]
Adafruit_I2CRegisterBits::Adafruit_I2CRegisterBits(Adafruit_I2CRegister *reg, uint8_t bits, uint8_t shift) {
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:105:106: error: no 'int Adafruit_BusIO_RegisterBits::Adafruit_I2CRegisterBits(Adafruit_I2CRegister*, uint8_t, uint8_t)' member function declared in class 'Adafruit_BusIO_RegisterBits'
src\Adafruit BusIO\Adafruit_I2CRegister.cpp:117:6: error: prototype for 'void Adafruit_BusIO_RegisterBits::write(uint32_t)' does not match any in class 'Adafruit_BusIO_RegisterBits'
void Adafruit_I2CRegisterBits::write(uint32_t data) {
In file included from C:\Users\joema\.platformio\lib\Adafruit BusIO/Adafruit_I2CRegister.h:1:0,
from src\Adafruit BusIO\Adafruit_I2CRegister.cpp:1:
C:\Users\joema\.platformio\lib\Adafruit BusIO/Adafruit_BusIO_Register.h:66:8: error: candidate is: bool Adafruit_BusIO_RegisterBits::write(uint32_t)
bool write(uint32_t value);
*** [.pio\build\esp32dev\src\Adafruit BusIO\Adafruit_I2CRegister.cpp.o] Error 1
