Fairly new to STM32 development, but I’m working on playing a simple 440Hz sin tone out of the STM32407’s on-board audio codec with I2C. When I upload the program using the Keil IDE after configuring with CubeMX, I get a 440Hz tone. But when I move all the files to Platform IO and upload using PIO’s STM32 library, I get a much lower sin tone.
My platform.ini
file…
[env:disco_f407vg]
platform = ststm32
board = disco_f407vg
framework = stm32cube
upload_protocol = stlink
; extra_scripts = extra_script.py
debug_tool = stlink
Are there any differences in the ways that PIO and the Keil IDE flash code onto the discovery that would somehow affect sampling rate or clock speeds?
Many thanks to anyone who can help out
Hard to say without the full code; could be anything.
https://drive.google.com/file/d/1AfIYRPmnY9Kq5naF2312dnl1fFM_DEpW/view?usp=sharing
There’s too much src to put in the comments so I zipped it up and put it above on google drive, hope this helps and lmk if there’s anything else I can put up!
You can ignore the lib
directory too, nothing is being called from there
Hm I don’t see anything really wrong with the code.
Note that the src\stm32f4xx_hal_conf.h
will not be used when compiling the STM32Cube framework size since PlatformIO generates a default one. If you want your file to be used, move that file to include/
and follow Stm32cube stm32XXX_hal_conf.h / Include search path - #3 by Rainer1 (but for the framework-stm32cubef4
/ F4 series ofc).
But the code is pretty simple so tracing it should give some insights.
First, there could be a difference in math libraries. In PlatformIO (Unified debugger) and Keil you should be able to place a breakpoint in main.c:133
to inspect the contents of the dataI2S
array (or, the first 218 elements of it). What are the contents of those arrays for the PlatformIO and Keil version respectively?
(You may also be able to just print them via UART / printf
Another thing to check would be if the Keil version behaves the same when you activate code optimizations. I’ve seen cases here where a difference in behavior was caused by Keil using no compiler optimization level or not optimizing something at all.
If that also reveals nothing, the I2C transfers to the audio codec should be checked, by e.g. adding printf()s into write_register()
of CS43L22.c
If that also doesn’t reveal anything (sent I2C configuration is identical, values in array which are supposed to be transmitted via I2S are identical), then one must take a logic analyzer and see what actual values are sent via I2S there, electrically, with a logic analyzer.
Seems as though I solved my issue! I changed the framework in platform.ini
to cmsis
instead of stm32cube
and with the addition of some STM32 drivers in my project path, I get my 440Hz sin tone…
Still going to try out some of those debugging techniques and circle back to see what specifically it was causing the problem. Your help is much appreciated, thanks again
Just for kicks, is there any way to load both the stm32cube framework and the cmsis layer so that I don’t have to externally add all the stm32f4xx_hal_*
library files manually to my project?
