I am using Ubidots to visualize data from NodeMCU devices. Everything works fine, but I really would like to get rid of a warning I get:
deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Library: GitHub - ubidots/ubidots-esp8266: Library for uploading ESP8266 devices to Ubidots
Using Ubidot’s library is very simple (API documentation), this is an example:
#include "UbidotsMicroESP8266.h"
#define TOKEN "Your_token_here" // Put here your Ubidots TOKEN
#define WIFISSID "Your_WiFi_SSID"
#define PASSWORD "Your_WiFi_Password"
Ubidots client(TOKEN);
void setup(){
delay(10);
client.wifiConnection(WIFISSID, PASSWORD);
void loop(){
float value = analogRead(A0);
float value2 = analogRead(A1);
float value3 = analogRead(A2);
client.add("Temperature", value);
client.add("Humidity", value2);
client.add("Heat Index", value3);
client.sendAll(true);
I get the warning at “Ubidots client(TOKEN);” and for every line where I use “client.add(“variable”, value);”.
Is this a problem of Ubidot’s library or can I solve it within Platformio?
Klaus
