I am quite sure there is some config in my ini file wrong but i can’t figure out which
so i am trying to compile a skech that works on arduino ide
this is my ini file:
[platformio]
description = test
env_default = UNO ;
lib_extra_dirs = D:\cloud\Programmi\Arduino\libraries
src_dir = examples\GoProControl
lib_dir = src
[env:UNO]
board = uno
my folder structure:
├───.pioenvs
├───.vscode
├───examples
│ ├───ESP32_FreeRTOS
│ ├───GoProControl
│ └───MultiCam
├───extras
└───src
and the Dependency Graph:
|-- <GoProControl> 0.9.3 (D:\cloud\Programmi\Arduino\libraries\GoProControl)
| |-- <ArduinoHttpClient> (D:\cloud\Programmi\Arduino\libraries\ArduinoHttpClient)
| |-- <VidorPeripherals> 1.1.0 (D:\cloud\Programmi\Arduino\libraries\VidorPeripherals)
| | |-- <SPI> 1.0 (C:\Users\vincenzo\.platformio\packages\framework-arduinoavr\libraries\__cores__\arduino\SPI)
| |-- <WiFi101> 0.15.3 (D:\cloud\Programmi\Arduino\libraries\WiFi101)
| |-- <WiFiEsp> 2.2.2 (D:\cloud\Programmi\Arduino\libraries\WiFiEsp)
| |-- <WiFiNINA> 1.3.0 (D:\cloud\Programmi\Arduino\libraries\WiFiNINA)
my header file is here: GoProControl/GoProControl.h at master · aster94/GoProControl · GitHub
as you can see the dependency grapf is wrong because it shouldn’t include all these library but only WiFiEsp
instead it include ALL the library that i have in my header file without considering the #if defined()
Does the same happen when lib_ldf_mode = deep+
(or chain+
) is written into the platformio.ini
? See Library Dependency Finder (LDF) — PlatformIO latest documentation and Redirecting...
thanks man! both chan+ and deep+ solve it
sorry i talked too early
the dependency graph are wrong, here include the libs twice:
first board:
second one:
| | |-- <SPI> 1.0 (C:\Users\vincenzo\.platformio\packages\framework-arduinoespressif8266\libraries\SPI)
| |-- <FreeRTOS> 9.0.0-1 (D:\cloud\Programmi\Arduino\libraries\FreeRTOS)
| |-- <ESP8266WiFi> 1.0 (C:\Users\vincenzo\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi)
ini file
[platformio]
description = test
env_default = UNO, ESP8266 ;UNO 101 ESP8266 ESP32
lib_dir = src
[env:UNO]
board = uno
lib_ldf_mode = chain+
[env:ESP8266]
platform = espressif8266
board = nodemcuv2
LDF running amok oO?
Can you, for each environment, declare the actually necessary libraries in a lib_deps
statement and the one PIO wrongly compiles in for the environment in lib_ignore
? I know this is cumbersome but that’d be a workaround.
See Redirecting...
aster94:
This is actually OK if the GoProControl
library includes ArduinoHttpClient
but some other main code (not located directly inside the GoProControl
includes the library too… Or it’s a side-effect of the chain evaluation… But does it compile with the first environment though?
This is actually OK if the GoProControl library includes ArduinoHttpClient but some other main code (not located directly inside the GoProControl includes the library too… Or it’s a side-effect of the chain evaluation… But does it compile with the first environment though?
the ArduinoHttpClient
is called only once (only in GoProControl.h) but yes it compiles correctly but this brings me to think that the ini file is somewhat wrong!
sure i can do it, but also i think that if this is the only way to do it how platformio include the liobrary should be modified!
okkk with @maxgerhardt workaround works. But still I think (really i hope) that i am doing something wrong. Because if i am doing all correct platformio should try to fix this problem
I am not marked this as solved
, even if Max was wonderful in helping me, because i would like that Ivan or someone for him see this problem
here there are my ini and compile logs
ini
[platformio]
description = test
;lib_dir = src
[env:UNO]
board = uno
lib_deps = WiFiEsp
lib_ignore =
WiFi101
WiFiNINA
ESP8266WiFi
VidorPeripherals
FreeRTOS
SPI
[env:ESP8266]
board = nodemcuv2
lib_deps = ESP8266WiFi
lib_ignore =
WiFi101
WiFiEsp
WiFiNINA
VidorPeripherals
SPI
FreeRTOS
esp:
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz 80KB RAM (4MB Flash)
xtensa-lx106-elf-g++ -o "D:\cloud\Programmi\Arduino\libraries\GoProControl\examples\GoProControl\GoProControl.ino.cpp" -x c++ -fpreprocessed -dD -E "c:\users\vincenzo\appdata\local\temp\tmpkt44_s"
LDF MODES: FINDER(chain+) COMPATIBILITY(soft)
Ignored library D:\cloud\Programmi\Arduino\libraries\FreeRTOS
Ignored library D:\cloud\Programmi\Arduino\libraries\VidorPeripherals
Ignored library D:\cloud\Programmi\Arduino\libraries\WiFi101
Ignored library D:\cloud\Programmi\Arduino\libraries\WiFiEsp
Ignored library D:\cloud\Programmi\Arduino\libraries\WiFiNINA
Ignored library d:\cloud\Programmi\Arduino\libraries\GoProControl\.piolibdeps\WiFiEsp_ID509
Ignored library C:\Users\vincenzo\.platformio\packages\framework-arduinoespressif8266\libraries\SPI
Collected 74 compatible librariesM
ore details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-modeScanning dependencies...
uno:
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR > Arduino Uno
HARDWARE: ATMEGA328P 16MHz 2KB RAM (31.50KB Flash)
avr-g++ -o "D:\cloud\Programmi\Arduino\libraries\GoProControl\examples\GoProControl\GoProControl.ino.cpp" -x c++ -fpreprocessed -dD -E "c:\users\vincenzo\appdata\local\temp\tmpxfgnaa"
Ignored library C:\Users\vincenzo\.platformio\packages\framework-arduinoavr\libraries\__cores__\arduino\SPI
Collected 74 compatible librariesMore details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
I will do it! thanks again
@maxgerhardt ivan said that this will be solved in pio 4.0 thanks
