I’m still in the process of finding out what is exactly going wrong (also having loads of “Access denied” messages again when downloading libraries in .cache folder during a build…
I’ll try to specify what used to work, and doesnt anymore (relevant file contents is below the text)
I have a project, which has a dependency on one of my private libraries named SenseFramework.
The private library SenseFramework has a number of dependencies, both on publicly available projects and on other private libraries of myself.
When i build the SenseFramework library by itself, everything is ok. Dependencies are installed, and it builds without problem.
When I build the main project, the dependency graph it shows looks like this:
|-- <SenseFramework> 0.0.1+sha.cf47264
| |-- <Wire> 1.0
| |-- <RTClib> 1.3.0
| | |-- <Wire> 1.0
| |-- <SoftwareSerial> 1.0
|-- <RTClib> 1.3.0
| |-- <Wire> 1.0
|-- <CRC32> 2.0.0
|-- <SPI> 1.0
As you can see im missing a lot of dependencies (i.e. MemoryFree, Sense_Timer, …), which are also not installed on build and therefor the build fails.
Before upgrading to 5.0.0 everything worked fine, and I used this setup for years with no problems
platform.io of my project (partly):
[env]
lib_ldf_mode = deep+
https://github.com/I-Connect/SenseFramework
-Werror=return-type
platform = espressif32@~1.12.0
lib_ignore = StandardCplusplus
As you can see, this project has a dependency on one of my libraries called SenseFramework.This library is not published as a package on platformio (and I don’t want to either)
platform.io of SenseFramework:
[platformio]
default_envs = esp32dev
[env]
GitHub - I-Connect/Sense_Timer: A fork of Simon Monk's Arduino Timer library
GitHub - I-Connect/StreamDebugger: StreamDebugger allows easier debugging of Serial-based communication on Arduino, like AT command interface in ESP8266, SIM800, SIM900, and other GSM modules
GitHub - sudar/MemoryFree: An Arduino library, that allows you to keep track of the amount of free memory that is available at runtime.
PubSubClient
Adafruit/RTCLib@1.3.0
-Wno-write-strings
-Werror=return-type
-DCORE_DEBUG_LEVEL=0
-DDEBUG_SENSE
-DDEBUG_NODEIDS=“26”
${env.lib_deps}
GitHub - I-Connect/Sense_SPIFFSIniFile: ESP8226 and ESP32 library to parse ini files
test_port = COM3
test_speed = 115200
[env:megaatmega2560]
platform = atmelavr@~1.15.0
board = megaatmega2560
${env.lib_deps}
GitHub - I-Connect/StandardCplusplus: Standard C++ for Arduino (port of uClibc++)
[env:ATmega328P]
board = ATmega328P
${env.lib_deps}
${env.build_flags}
-Wno-aggressive-loop-optimizations
library.json:
“name”: “SenseFramework”,
“version”: “0.0.1”,
“description”: “Hardware independent Arduino framework for working with Observable Nodes, Observers and other generic classes”,
“keywords”: “observable,observer,node”,
“authors”: [
“name”: “Bas Schouten”,
“maintainer”: true
“name”: “Jeroen van de Vorst”
“repository”: {
“type”: “git”,
“url”: “I-Connect/SenseFramework”
“frameworks”: “Arduino”,
“platforms”: [
“espressif32”,
“atmelavr”
“build”: {
“flags”: “-Wno-unused-function”
“dependencies”: [
“name”: “GitHub - I-Connect/Sense_Timer: A fork of Simon Monk's Arduino Timer library”
“name”: “StreamDebugger”,
“version”: “GitHub - I-Connect/StreamDebugger: StreamDebugger allows easier debugging of Serial-based communication on Arduino, like AT command interface in ESP8266, SIM800, SIM900, and other GSM modules”
“name”: “MemoryFree”,
“version”: “GitHub - sudar/MemoryFree: An Arduino library, that allows you to keep track of the amount of free memory that is available at runtime.”
“name”: “PubSubClient”
“name”: “Wire”
“name”: “RTCLib”,
“version”: “Adafruit/RTCLib@1.3.0”
“platforms”: “atmelavr”,
“name”: “StandardCplusplus”,
“version”: “GitHub - I-Connect/StandardCplusplus: Standard C++ for Arduino (port of uClibc++)”
“platforms”: “espressif32”,
“name”: “Sense_SPIFFSIniFile”,
“version”: “GitHub - I-Connect/Sense_SPIFFSIniFile: ESP8226 and ESP32 library to parse ini files”
