I’m using platformio / vscodium only occasionally.
Compile & Link has been working in the past. But now it seems that the default include path is broken.
After opening an existing project I first cleaned it.
* Executing task in folder RainWaterControl.ESP32: platformio run --target clean
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
Removing .pio/build/esp32doit-devkit-v1
Done cleaning
Then I tried to build
PLATFORM: Espressif 32 (6.4.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 @ 3.20011.230801 (2.0.11)
Found 58 compatible libraries
|-- ESPAsync_WiFiManager_Lite @ 1.10.5
|-- ESP Async WebServer @ 1.2.3+sha.8e9c5a6
|-- ESPAsyncDNSServer @ 1.0.0+sha.3c6627d
|-- AsyncMqttClient @ 0.9.0
|-- AsyncElegantOTA @ 2.2.8
|-- WiFi @ 2.0.0
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/Esp.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/FirmwareMSC.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/FunctionalInterrupt.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/HWCDC.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/HardwareSerial.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/IPAddress.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/IPv6Address.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/MD5Builder.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/Print.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/Stream.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/StreamString.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/Tone.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/USB.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/USBCDC.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/USBMSC.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/WMath.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/WString.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/base64.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/cbuf.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-adc.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-bt.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-cpu.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-dac.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-gpio.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-i2c-slave.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-i2c.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-ledc.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-matrix.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-misc.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-psram.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-rgb-led.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-rmt.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-sigmadelta.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-spi.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-time.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-timer.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-tinyusb.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-touch.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-uart.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/firmware_msc_fat.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/libb64/cdecode.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/libb64/cencode.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/main.cpp.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/stdlib_noniso.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/wiring_pulse.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/FrameworkArduino/wiring_shift.c.o' from cache
Retrieved `.pio/build/esp32doit-devkit-v1/libFrameworkArduino.a' from cache
Linking .pio/build/esp32doit-devkit-v1/firmware.elf
/data/PlatformIO/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32doit-devkit-v1/src/asyncMQTT_onMessage.cpp.o: in function `onMqttMessage(char*, char*, AsyncMqttClientMessageProperties const&, unsigned int const&, unsigned int const&, unsigned int const&)':
/data/PlatformIO/Projects/RainWaterControl.ESP32/src/asyncMQTT_onMessage.cpp:12: multiple definition of `onMqttMessage(char*, char*, AsyncMqttClientMessageProperties const&, unsigned int const&, unsigned int const&, unsigned int const&)'; .pio/build/esp32doit-devkit-v1/src/asyncMQTT.cpp.o:/data/PlatformIO/Projects/BoilerPlate.ESP32/src/asyncMQTT.cpp:199: first defined here
*** [.pio/build/esp32doit-devkit-v1/firmware.elf] Error 1
As you can see, that the Linker tries to combine files from my current project directory.
and another project directory
I did not understand why this is happening. The default include path is just to include everything below project directory.
Found include_dir in Platformio docs, but this is only about adding dirs.
And there is no include directive in my platformio.ini
please enlighten me
