Deep sleep maximum time 8266
So this function is defined as
And thus uint64_t means the range of this value is between 0 and (2^64)-1 equals
18446744073709551615
your expression evaluates to
2220000000
which is below the max value; however you are doing int aka int32_t arithmetic when you don’t suffix the values with stuff like U, UL or ULL. And int32_t has a range of
−2147483648 (most negative)
2147483647 (most positive)
2220000000 (your number)
so as you can see you are above the int32_t limit; No need to worry though, just do unsigned long long arithmetic (for uint64_t) and write
 #define SleepTime (35ULL* 60ULL* 1000000ULL)
and you should be good to go.
Too-long-didn’t-read-version: You made a int32_t overflow, use ULLto calculate sleep time as the correct uint64_t value.
