Debugging with PlatformIO: Part 1. Back to the Basics
@thomas.kilian.0815 I’m not sure I did the right thing. Can you tell me what I did is correct please ?
In my platformio projet, I found inside the .vscode folder a file “launch.json” that I modified to add the configuration you mentioned. So my “launch.json” looks like this :
// PlatformIO Debugging Solution
// Documentation: https://docs.platformio.org/en/latest/plus/debugging.html
// Configuration: https://docs.platformio.org/en/latest/projectconf/sections/env/options/debug/index.html
    "version": "0.2.0",
    "configurations": [
            "name": "(lldb) Starten",
            "type": "cppdbg",
            "request": "launch",
            "program": "/Users/guillaumecostes/Documents/PlatformIO/Projects/231218-164431-hello-world/.pio/build/native/program",
            "args": [],
            "stopAtEntry": false,
            "cwd": "${fileDirname}",
            "environment": [],
            "externalConsole": false,
            "MIMode": "lldb"
            "type": "platformio-debug",
            "name": "PIO Debug",
            "executable": "/Users/guillaumecostes/Documents/PlatformIO/Projects/231218-164431-hello-world/.pio/build/native/program",
            "projectEnvName": "native",
            "toolchainBinDir": "/usr/bin",
            "internalConsoleOptions": "openOnSessionStart",
            "preLaunchTask": {
                "type": "PlatformIO",
                "task": "Pre-Debug"
            "name": "PIO Debug (without uploading)",
            "loadMode": "manual"
And I modified my platformio.ini like this :
[env:native]
platform = native
  -g
But I still have the same problem when i try to start debugger.
I’m still busy with other things… I’ll try to look into it soon (latest the weekend)
Got it working again. Inside launch.json I hardcoded the executable path
 "version": "0.2.0",
  "configurations": [
      "type": "cppdbg",
      "program": "/Users/thomaskilian/Documents/PlatformIO/Projects/240105-130152-hello-world/src/build/Debug/main.o",
      "args": [],
      "environment": [],
      "MIMode": "lldb"
I guess you can use env-vars, but that started the lldb. It will ask for passwort/fingerprint but that’s (more or less) okay since you can debug aftrewards. Keeps that for a while so you can restart debugging without the prompt.
This does not seem like the program file created by PlatformIO, wihh would be <project folder>/.pio/build/<environment name>/program, so you might be using some other extension for building.
You don’t need to do this. Just add
[env:native]
build_type = debug
Build firmware in the debug mode and try debugging with cppdbg extension.
Well, this is my path and you have to replace it with yours or use the env-vars. The path ia where PIO compiled the hello-world to.
Thank you @ivankravets I tried it. But if by “cppdbg extension” you mean the native debug extension for vscode, it is not working, I still have the same error.
Thank you for the tips @thomas.kilian.0815.
I modified my launch.json like this with my own main.o path:
    "version": "0.2.0",
    "configurations": [
            "targetArchitecture": "arm64",
            "type": "cppdbg",
            "program": "/Users/guillaumecostes/Documents/PlatformIO/Projects/231218-164431-hello-world/.pio/build/native/src/main.o",
            "args": [],
            "environment": [],
            "MIMode": "lldb"
            "preLaunchTask": {
                "task": "Pre-Debug"
It is kind of working since I do not get the previous error. And if i forget to make a build, It tells me that my path “…/main.o” does not exists. But after building, I do not have this error, so I think it can find the main.o file.
BUT now i got this error :
ERROR: Unable to start debugging. Unexpected LLDB output from command "-exec-run". Command 'exec-run'. Invalid process during debug session
The program '/Users/guillaumecostes/Documents/PlatformIO/Projects/231218-164431-hello-world/.pio/build/native/src/main.o' has exited with code 42 (0x0000002a).
I did some research. I found the exact same issue on a forum :
so I tried the solution and installed the CodeLLDB extension, then modified “type”: “cppdbg”, to “type”: “lldb”. I tried again to debug. This time, I got a popup message with “Permission denied” that proposes me to check the launch.json file. So I check, some field of the configuration are highlighted as “not allowed properties” so i removed those fields, but I still get the “Permission denied” popup.
A made some research about the permission denied with debugger, but nothing that could match my case.
So I don’t know what to do to make it work.
You should make a new project from the hello-world template and try that before doing complicated stuff…
I’m using a simple projet, I just followed the tutorial. So it is based on the hello-world template, only the main code is modified with the add of a sort array function like in the tutorial. So I don’t think the problem comes from the project.
