I have been trying for several days now to set up debugging for esp32 boards. I have tried both an ftdi mini-module and an esp-prog board. I have changed computers and tried and tried different combinations of esp32 (pico and wroom-32) and jtag (ftdi and esp-prog) boards. This would suggest a setup error. I’ve searched the community forum. I’ve done all the usual checks. I have: checked, rechecked and re-setup the wiring numerous times and verified against several tutorials and the original datasheets. TCK - IO13, TDI-IO12, TDO - IO15, TMS - IO14; plus GND - GND; set up winusb on the ftdi and esp-prog channel 0; tried shorter cables, reduced the adapter speed etc., tried different configuration files etc; used different laptops but all to no avail, checked the debug-tool setting in platform.ini. So I am really at a loss of what to try next.
Any thoughts would be very much appreciated.
Below is a short extract of the error log:
Info : FreeRTOS creation
adapter speed: 20000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Warn : Bypassing JTAG setup events due to errors
Warn : No symbols for FreeRTOS!
Error: Target not examined yet
Error executing event gdb-attach on target esp32.cpu0:
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error: error during select: Unknown error
Remote communication error. Target disconnected.: No error.
