I am trying to use one Sipeed Longan nano to debug another one. When I click on Start Debugging I get this
Verbose mode can be enabled via -v, --verbose
option
KeyError: “Invalid board option ‘build.ldscript’”:
File “U:\LonganIDE.platformio\penv\Lib\site-packages\platformio\builder\main.py”, line 175:
env.SConscript(item, exports=“env”)
File “U:\LonganIDE.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py”, line 591:
File “U:\LonganIDE.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py”, line 280:
exec(compile(scriptdata, scriptname, ‘exec’), call_stack[-1].globals)
File “X:\Firmware\RV-link_longan\proj\build.py”, line 65:
LDSCRIPT_PATH = join(PROJ_DIR, “src”, “link”, “gd32vf103c-start”, “RISCV”, “gcc”, board.get(“build.ldscript”))
File “u:\longanide.platformio\penv\lib\site-packages\platformio\platform\board.py”, line 59:
raise KeyError(“Invalid board option ‘%s’” % path)
This is my platformio.ini
[env:sipeed-longan-nano]
platform = gd32v
framework = gd32vf103-sdk
board = sipeed-longan-nano
debug_tool = sipeed-rv-debugger
I have uploaded the RV Link debug project from this sipeed page
Using RV-LINK · Longan DOC (sipeed.com)
This is the platformioi rv-link project I downloaded
http://dl.sipeed.com/LONGAN/Nano/Tools/RV-LINK-pio-src-v0.1.zip
I changed the upload from dfu to serial, as I cant get dfu work to at all.
I used a FTDI 232 to program the nano over serial, using this platformio.ini
Blockquote; PlatformIO Project Configuration File
; Build options: build flags, source filter, extra scripting
; Upload options: custom port, speed and extra flags
; Redirecting...
[env:sipeed-longan-nano-rv]
platform = gd32v
;framework = gd32vf103-sdk
upload_protocol = serial
-DGD32VF103C_START
-DUSE_STDPERIPH_DRIVER
-DUSE_USB_FS
-DLINK_LONGAN_NANO
-DTARGET_GD32VF103
-DAPP_GDB_SERVER
-DRVL_ASSERT_EN
-MMD
extra_scripts =
pre:build.py
src_filter =
+<*>-<.git/>-<.svn/>----
-<app/riscv-prober>
-<app/test-usb-serial/>
-<link/gd32vf103c-start/rvl-link.c>
-<link/gd32vf103c-start/rvl-button.c>
-<link/gd32vf103c-start/rvl-led.c>
-<link/gd32vf103c-start/rvl-jtag.c>
-<link/gd32vf103c-start/gd32vf103c_start.c>
-<link/gd32vf103c-start/rvl-jtag-inline.h>
-<link/rvl-link-stub.c>
-<link/gd32vf103c-start/RISCV/gcc/>
+<link/gd32vf103c-start/RISCV/gcc/init.c>
+<link/gd32vf103c-start/RISCV/gcc/handlers.c>
+<link/gd32vf103c-start/RISCV/gcc/entry.S>
+<link/gd32vf103c-start/RISCV/gcc/start.S>
-<link/gd32vf103c-start/RISCV/stubs>
+<link/gd32vf103c-start/RISCV/stubs/sbrk.c>
-<link/gd32vf103c-start/GD32VF103_standard_peripheral/>
+<link/gd32vf103c-start/GD32VF103_standard_peripheral/system_gd32vf103.c>
+<link/gd32vf103c-start/GD32VF103_standard_peripheral/Source/gd32vf103_gpio.c>
+<link/gd32vf103c-start/GD32VF103_standard_peripheral/Source/gd32vf103_rcu.c>
+<link/gd32vf103c-start/GD32VF103_standard_peripheral/Source/gd32vf103_timer.c>
+<link/gd32vf103c-start/GD32VF103_standard_peripheral/Source/gd32vf103_eclic.c>
+<link/gd32vf103c-start/GD32VF103_standard_peripheral/Source/gd32vf103_exti.c>
+<link/gd32vf103c-start/GD32VF103_standard_peripheral/Source/gd32vf103_pmu.c>
Blockquote
It looks like it worked, I have a green LED flashing.
Then the second nano I want to debug, so I connected them all like this
FT232 Nano Debugger RV-Link Program to debug Nano
Rx Tx
Tx Rx
VCC 3.3V
GND GND
TDO TDO
TDI TDI
TCK TCK
TMS TMS
Any ideas ?
Thanks
Marcus
