I am attempting to use the ti-icdi debugger on the EK-TM4C123GXL board. I am getting a warning that I should be using a different board configuration file which I tried to address in my platform.ini file but it looks like the platform.ini file is not being seen.
I am able to upload the firmware to my board, but I am not able to debug it.
platform.ini
[env: a]
platform = titiva
board = lptm4c123gh6pm
debug_tool = ti-icdi
upload_protocol = ti-icdi
debug_server =
$PLATFORMIO_CORE_DIR/packages/tool-openocd/bin/openocd
-f
$PLATFORMIO_CORE_DIR/packages/tool-openocd/scripts/board/ti_ek-tm4c123gxl.cfg
CONFIGURATION: https://docs.platformio.org/page/boards/titiva/lptm4c123gh6pm.html
PLATFORM: TI TIVA (3.0.1) > TI LaunchPad (Tiva C) w/ tm4c123 (80MHz)
HARDWARE: LPTM4C123GH6PM 80MHz, 32KB RAM, 256KB Flash
DEBUG: Current (ti-icdi) On-board (ti-icdi)
- framework-energiativa 1.10002.0 (1.0.2)
- tool-openocd 2.1000.200630 (10.0)
- toolchain-gccarmnoneeabi 1.40804.0 (4.8.4)
Found 22 compatible libraries
Checking size .pio\build\ a\firmware.elf
RAM: [ ] 1.6% (used 520 bytes from 32768 bytes)
Flash: [ ] 1.0% (used 2616 bytes from 262144 bytes)
AVAILABLE: ti-icdi
CURRENT: upload_protocol = ti-icdi
Uploading .pio\build\ a\firmware.bin
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-09:29)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
**WARNING: board/ek-tm4c123gxl.cfg is deprecated, please switch to board/ti_ek-tm4c123gxl.cfg**
Error: SRST error
Error: SRST error
xPSR: 0x01000000 pc: 0x00000630 msp: 0x20008000
** Programming Started **
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
Error: SRST error
shutdown command invoked
