I tried a Project without Timers same result
#include "Arduino.h"
#include "WString.h"
#include "SPI.h"
#include <WROVER_KIT_LCD.h>
#include <Adafruit_GFX.h> // Hardware-specific library
#include <WiFiUdp.h>
#include <WiFi.h>
#include <ESPmDNS.h>
#include "Tabelle.h"
#include <time.h>
#include "StatusBar4Time.h"
#include "WiFi_config.h"
#include "comic8pt.c"
#include "comici10pt.c"
#include "comici_grad10pt.c"
#include "Fonts/FreeMonoBoldOblique12pt7b.h"
WROVER_KIT_LCD tft = WROVER_KIT_LCD();
WiFiUDP udp;
TabelleClass Table;
StatusBar4TimeClass * StatusBar;
tm timeinfo;
time_t now;
uint32_t ZeitCounterNew = 0;
uint32_t ZeitCounterOld = 0;
// Prototypes ***************************************************
void InitILI9341();
void GetNPTime();
bool GetNTP_Time(int sec);
String GetTime(tm localTime);
void Gradient(uint16_t X, uint16_t Y, uint16_t width, uint16_t heigth, uint16_t Farbe, uint16_t ColorMask);
void connectToWiFi(const char * ssid,
const char * pwd);
void WiFiEvent(system_event_id_t event);
template<typename ... Args>
String Format( String& format, Args ... args );
String GetUDPDatas(void);
void SentUDPPacket(const char Text[]);
void ScanWiFiSSID();
String authModeToText(wifi_auth_mode_t authMode);
void PrintText(uint16_t X, uint16_t Y,
const char * Text, uint16_t Color);
// End Prototypes *************************************************
// Callback function to be called when the button is pressed.
void onPressed() {
Serial.printf("Status is %d", CountMerker);
/// SETUP----SETUP----SETUP----SETUP----SETUP
void setup()
ifdef ILI9341 // Init LCD Display
InitILI9341();
endif
connectToWiFi(sBufferSSID, sBufferPASS);
uint32_t Versuch = 0;
while ((WiFiConnected == false) & (Versuch++ < 500))
Serial.printf(". %d - %d", Versuch, WiFiConnected);
delay(100);
if (WiFiConnected == false)
Serial.println("Fuck the SYstem");
Serial.println("Restart the SYstem");
ESP.restart();
tft.fillScreen(ILI9341_DARKGREEN);
Table.initTable( & tft, 1, ILI9341_WHITESMOKE, ILI9341_BROWN, ILI9341_NAVY);
ScanWiFiSSID();
delay(3000);
tft.fillScreen(ILI9341_NAVY);
tft.setFont( & FreeMonoBoldOblique12pt7b);
StatusBar = new(StatusBar4TimeClass);
StatusBar - > init( & tft, ILI9341_AQUAMARINE, ILI9341_RED, ILI9341_RED);
StatusBar - > SetTime(0, 0xffffffff);
GetNPTime();
/// LOOP----LOOP----LOOP----LOOP----LOOP----
void loop()
String Result = "";
StatusBar - > SetTime(ZeitCounterNew, ZeitCounterOld);
ZeitCounterOld = ZeitCounterNew;
ZeitCounterNew++;
if (WiFiConnected)
GetNTP_Time(10);
GetTime(timeinfo);
delay(100);
bTriggerSNMP = false;
/// UDP SentUDPPacket(Datum);
Result = "";
Result = GetUDPDatas();
if (Result != "")
Serial.print("---->");
Serial.println(Result);
} /// End WiFiConnected
} /// End Loop
uint16_t dx, rgb;
uint8_t n;
dx = width / 32;
for (n = 0; n < 33; n++) {
rgb = n * 8;
rgb = tft.color565(rgb, rgb, rgb);
tft.fillRect(n * dx, Y - 3, dx, heigth, rgb & ColorMask);
tft.drawRoundRect(X, Y, width - 1, heigth, 10, Farbe);
const char * pwd)
Serial.printf(Buffer, "Connecting to WiFi network : %s", ssid);
// delete old config
WiFi.disconnect(true);
//register event handler
WiFi.onEvent(WiFiEvent);
//Initiate connection
WiFi.begin(ssid, pwd);
WiFi.setHostname("ESP32_Login");
//wifi event handler
Serial.print("event ");
Serial.print(event);
switch (event)
case SYSTEM_EVENT_WIFI_READY:
Serial.print("Wifi Ready");
break;
case SYSTEM_EVENT_STA_START:
Serial.print("Wifi Event Start");
break;
case SYSTEM_EVENT_STA_STOP:
Serial.print("Wifi Event Stop");
break;
case SYSTEM_EVENT_STA_CONNECTED:
Serial.print("WiFi connected");
break;
case SYSTEM_EVENT_STA_DISCONNECTED:
Serial.print("Wifi Disconnected");
break;
case SYSTEM_EVENT_STA_GOT_IP:
udp.begin(WiFi.localIP(), UDP_PORT);
WiFiConnected = true;
break;
case SYSTEM_EVENT_STA_LOST_IP:
Serial.print("Wifi lost IP");
WiFiConnected = false;
break;
default:
Serial.print("Not recognized Wifi Event ");
//only send data when connected
if (WiFiConnected)
//Send a packet
udp.beginPacket(UDP_SERVER_IP, UDP_PORT);
udp.print(Text);
udp.endPacket();
char buffer[50] = "";
udp.parsePacket();
//receive response from server, it will be HELLO WORLD
if (udp.read(buffer, 50) > 0) {
Serial.print("Server to client: ");
Serial.println((char * ) buffer);
return (buffer);
tft.setTextColor(Color, ILI9341_Background); // Navy is Background
tft.setCursor(X, Y);
tft.print(Text);
void ScanWiFiSSID()
define LineY1 175
# define LineY2 225
String S;
tft.fillScreen(ILI9341_Background);
tft.setTextSize(1);
Serial.println("Suche läuft.");
const uint8_t n = WiFi.scanNetworks();
Table.Init_Table_Items(n, Table.Items3);
Table.initHeadline("SSID", "RSSI", "Auth-Mode", ILI9341_WHITESMOKE);
if (n == 0) {
} else {
Serial.print(n);
Serial.println(" Networks probed");
Serial.println("---------------------------------+------+----------------");
Serial.println(" SSID | RSSI | AUTH MODE ");
for (uint8_t i = 0; i < n; i++)
S = WiFi.SSID(i);
Serial.printf("%32.32s | ", S.c_str());
Table.AddItem(S, Table.Items1);
int32_t RSSI = WiFi.RSSI(i);
Serial.printf("%4d | ", RSSI);
S = RSSI;
Table.AddItem(S, Table.Items2);
S = WiFi.encryptionType(i);
Serial.printf("%15s\n", S.c_str());
Table.AddItem(S, Table.Items3);
Table.ShowItems();
switch (authMode) {
case WIFI_AUTH_OPEN:
return "Offen";
case WIFI_AUTH_WEP:
return "WEP";
case WIFI_AUTH_WPA_PSK:
return "WPA PSK";
case WIFI_AUTH_WPA2_PSK:
return "WPA2 PSK";
case WIFI_AUTH_WPA_WPA2_PSK:
return "WPA/WPA2 PSK";
case WIFI_AUTH_WPA2_ENTERPRISE:
return "WPA2 ENTERPRISE";
case WIFI_AUTH_MAX:
return "MAX";
default:
return "Unbekannt";
void InitILI9341()
Serial.print("****** TFT Mode ******");
tft.begin();
pinMode(TFT_LED, OUTPUT);
digitalWrite(TFT_LED, HIGH);
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(WROVER_RDDST);
Serial.print("Status: 0x");
Serial.println(x, HEX);
x = tft.readcommand8(WROVER_RDDPM);
Serial.print("Power Mode: 0x");
x = tft.readcommand8(WROVER_RDDMADCTL);
Serial.print("MADCTL Mode: 0x");
x = tft.readcommand8(WROVER_RDDCOLMOD);
Serial.print("Pixel Format: 0x");
x = tft.readcommand8(WROVER_RDDIM);
Serial.print("Image Format: 0x");
x = tft.readcommand8(WROVER_RDDSDR);
Serial.print("Self Diagnostic: 0x");
tft.setTextSize(1);
tft.setTextWrap(false);
tft.setRotation(1); // horizontal display
void GetNPTime()
configTime(0, 0, NTP_SERVER);
// See https://github.com/nayarsystems/posix_tz_db/blob/master/zones.csv for Timezone codes for your region
setenv("TZ", TZ_INFO, 1);
if (GetNTP_Time(10)) { // wait up to 10sec to sync
Serial.println("NPT OK !");
} else {
Serial.println("Time not set");
ESP.restart();
GetTime(timeinfo);
lastNTPtime = time( & now);
lastEntryTime = millis();
uint32_t start = millis();
do {
time( & now);
localtime_r( & now, & timeinfo);
delay(10);
} while (((millis() - start) <= (1000 * sec)) && (timeinfo.tm_year < (2016 - 1900)));
if (timeinfo.tm_year <= (2016 - 1900)) return false; // the NTP call was not successful
Serial.print("now ");
Serial.println(now);
char time_output[30];
strftime(time_output, 30, "%a %d-%m-%y %T", localtime( & now));
Serial.println(time_output);
Serial.println();
return true;
Serial.print(localTime.tm_mday);
Serial.print('/');
Serial.print(localTime.tm_mon + 1);
Serial.print('/');
Serial.print(localTime.tm_year - 100);
Serial.print('-');
Serial.print(localTime.tm_hour);
Serial.print(':');
Serial.print(localTime.tm_min);
Serial.print(':');
Serial.print(localTime.tm_sec);
Serial.print(" Day of Week ");
if (localTime.tm_wday == 0) Serial.println(7);
else Serial.println(localTime.tm_wday);
return ("Hallo");
