I’m getting the following error message popup window when I try to invoke JTAG debugging:
“Visual Studio Code, Failed to launch GDB: Error: write EPIPE” with the buttons “Open launch.json” and “Cancel”
Here is my software configuration: Win10, Visual Studio ver. 1.50.1, Platformio core 5.0.1, home 3.30
Here is my hardware configuration: ESP32s connected to an Olimex “ARM-USB-OCD-H”. Both USB drivers appear to be installed correctly. I don’t have anything connected to pins 1 or 2 of the Olimex and the esp32 is powered by a separate USB port. I double-checked the other 5 (plus ground) connections to the ESP32. I’m admittedly new to both Olimex, JTAG, and Platformio. I have programmed my esp32 through a USB connection and seen the serial port output successfully but now I would like to get debugging working. Please help.
