Looks like I have to resurrect this thread…
I have tried, to the best of my abilities (which doesn’t necessarily say much…  ), to follow the suggestions in this thread, but I’m stuck with a different problem.
I’m using a custom board with a Rigado BMD-300 module, based on nRF52832, and I have looked at several different nRF52832-based boards’ JSON-files to cook up a suitable JSON-file for my board, but  when I try to build, I get the error message: "Error: Could not load broken JSON ". I have tried to put the JSON-file and the accommodating variant.xxx and pins_arduino.h in the appropriate folders both in my project directory and in the C:\Users<etc,etc>\framework-arduinonordicnrf5 folder, without any luck.
My platformio.ini
[env:MyBoardNRF5]
platform		= nordicnrf52
board			= MyBoardNRF5
framework		= arduino
board_build.mcu = nrf52832
monitor_speed	= 115200
monitor_port	= COM10
upload_protocol	= blackmagic
	-I variants/MyBoardNRF5
	mysensors/MySensors@^2.3.2
	adafruit/Adafruit BME280 Library@^2.2.2
My MyBoardNRF5.json:
  "build": {
    "arduino": {
        "ldscript": "nrf52_xxaa.ld"
    "core": "nRF5",
    "cpu": "cortex-m4",
    "f_cpu": "64000000L",
    "mcu": "nrf52832",
    "variant": "MyBoardNRF5",
    "variants_dir" : "variants"
  "debug": {
    "jlink_device": "nRF52832_xxAA",
    "openocd_chipname": "nrf52832",
    "openocd_target": "nrf52832",
    "svd_path": "nrf52.svd",
  "frameworks": [
    "arduino"
  "name": "MyBoardNRF5",
  "upload": {
    "maximum_ram_size": 65536,
    "maximum_size": 524288,
	"require_upload_port": true,
	"speed": 115200,
    "protocol": "jlink",
    "protocols": [
      "stlink",
      "blackmagic",
      "jlink",
      "nrfjprog",
	  "cmsis-dap",
	  "nrfutil"
  "url": "https://www.mysensors.org",
  "vendor": "Generic"
Anyone able to spot where I’ve goofed up?
PlatformIO is 6.1.6a4, running in VS Code 1.74.2
Edit: I don’t know if “nrf52_xxaa.ld” and “nrf52.svd” needs to be put somewhere or if they are loaded from somewhere automatically? If it is not done automatically, where can I find them and where should they be put?
