I’m on win10 and I installed via vscode using a portable vscode install as specified here. However, pio library storage location (as reported from cli command pio update) is C:\.platformo\lib
. For strategic reasons, I’d like to keep the libraries on removable media as well. Is there a setting equivalent to projects_dir
? Are there any strategic disadvantages to relocating?
Many thanks in advance
Joe
Per documentation
globallib_dir
Default: “core_dir/lib”
Global library storage for PlatfrmIO projects and Library Management where Library Dependency Finder (LDF) looks for dependencies.
This option can also be configured by the global environment variable PLATFORMIO_GLOBALLIB_DIR
And core_dir
by default is %HOMEPATH%\.platformio
(docs).
Oh, I see, because it’s a project level setting and not a system level setting.
Right?
If you set the environment variable as documented it will be system-level.
Right, but I’m saying it’s separate from projects_dir because it’s not project specific.
