I tried to make a custom board variant. I did the following:
find the folder where the variants of similar boards are located
copy and rename the variant_xxx.cpp, variant_xxx.h, variant_xxx.c from the closest board and made the pinout changes according to the actual HW in variant_xxx.h
add the new variant to board.txt (copy and modified from the closest variant)
copied and renamed the new xxx.json board definition and defined the correct variant
A few hours later it worked as intended … but:
variant_xxx.c and variant_xxx.cpp ask for a define like:
Do I interpret correctly that this definition should be autogenerated during the built so I don’t have to do something?
The funny thing is it works today. Yesterday I needed to comment the " #if defined(ARDUINO_MY_BOARD)" out but today it works w/o that. But most likely I have looked wrongly yesterday and the bug was something else … Anyway thanks for the help and the fast response!
