Criterias of buildflag -I
Allow me to ask you a question in return: What exactly do you want to achieve?
I assume you want to use a central directory where your private libraries are located.
In this case, the correct approach would be to create a proper file structure and use symlink in the lib_deps setting as described here: Lib_deps creating different versions of included file? - #4 by sivar2311
