Hi there,
I started to work on a project for an ATmel328P.
The project source file are contained only inside a src folder and there is no an .ino file.
Only the main.c plus several libraries (.c + *.h).
I have only the makefile (https://gist.github.com/mcous/5920089).
I can compile without errors and now I’m wonder if it possible to debug the code from linux.
I looking for a solution using VS Code + Platformio but I don’t know how to start and I want to mantain the original folder structure.
Basically all the code must be inside the src folder.
Any help will be appreciated.
BR, Federico
