Create a new library
Hello everyone, I am a novice of Arduino and Platformio, also I tell you that I am Italian and since I have a bit of difficulty with English I am writing to you via google translator.
I am trying to learn, through web searches, to write a small library with the relative file .h .cpp and keyword.txt, and I am attaching the codes below
File .h
#ifndef Morse_h
#define Morse_h
#include "Arduino.h"
class Morse {// the class is defined
   public:
      Morse (int pin);
      void dot ();
      void dash ();
   private:
      int _pin;
File .cpp
#include "Morse.h"
Morse :: Morse (int pin) {
pinMode (pin, OUTPUT);
_pin = pin;
void Morse :: dot () {
digitalWrite (_pin, HIGH);
delay (250);
digitalWrite (_pin, LOW);
delay (250);
void Morse :: dash () {
delay (1000);
delay (250);
File Keyword
Morse KEYWORD1
dash KEYWORD2
dot KEYWORD2
But if I compile these files through the arduino IDE everything works, while if I compile it with platformio, I write this error here
C: \ Users \ MOSBON ~ 1 \ AppData \ Local \ Temp \ ccNHvu7R.ltrans0.ltrans.o: In function main ': <artificial> :(. text.startup + 0x8e): undefined reference to Morse :: dot () ’
:(. text.startup + 0x96): undefined reference to Morse :: dot () ' <artificial> :(. text.startup + 0x9e): undefined reference to Morse :: dot () ’
:(. text.startup + 0xa6): undefined reference to Morse :: dash () ' <artificial> :(. text.startup + 0xae): undefined reference to Morse :: dash () ’
:(. text.startup + 0xb6): undefined reference to Morse :: dash () ' <artificial> :(. text.startup + 0xbe): undefined reference to Morse :: dot () ’
:(. text.startup + 0xc6): undefined reference to Morse :: dot () ' <artificial> :(. text.startup + 0xce): undefined reference to Morse :: dot () ’
C: \ Users \ MOSBON ~ 1 \ AppData \ Local \ Temp \ ccNHvu7R.ltrans0.ltrans.o: In function _GLOBAL__sub_I_morse ': <artificial> :(. text.startup + 0x134): undefined reference to Morse :: Morse (int) ’
*** [.pio \ build \ uno \ firmware.elf] Error 1
Can you help me please?
Thanks to everyone who dedicated some time to me
Sorry I forgot to enter the sketch code
#include <Morse.h>
Morse morse(13);
void setup(){
void loop(){
morse.dot();
morse.dot();
morse.dot();
morse.dash();
morse.dash();
morse.dash();
morse.dot();
morse.dot();
morse.dot();
delay(3000);
Can you show a screenshot of the folder structure in VSCode? I don’t see an error in your code.
Immagine 2021-03-15 141012
include/ folder is for .h files only – the CPP files in there will not be compiled.
You should create a new folder in lib (e.g. Morse) and put the 3 files in there.
(Also, the keyword.txt file is not processed by PlatformIO, only by the Arduino IDE).
