I’ve posted a few times about this, but I keep learning new things.
I put this ESP Now project away last April, but it didn’t work at all when I dusted it off.
The senders appeared to be working, sending successfully but not delivering. I got good sensor data from serial output.
The receiver would ‘work’ a few times, then gibberish serial output happened. I could unplug and replug and get gibberish.
This morning, PIO serial showed me gibberish, but Termite shows sane output.
I’d upload the receiver program again, and it would work- the serial output was correct. But none of the sender data was being reported. All the variables were = 0.
And then it would go to gibberish. This went on for a few weeks.
Without changing any code, the receiver started receiving yesterday. I got it to receive from both the R32 and the WeMos/32 Mini.
But the webserver still isn’t working. It’s giving me an IP address, but the page won’t load.
And the temperature is 140,000 degrees. That’s not right. Sender said ~15C.
This morning, I plugged in the receiver (R32) , and it’s working okay. I feel like I’ve posted the code too many times, but I really need that webserver to work.
Does anybody think they might be able to see a problem in webserver code?
Can you imagine why the receiver is reporting some data wildly, changing ‘19’ to ‘140,000’ while almost everything else appears right?
And it’s reporting a 1m altitude as 105,000, derived from pressure. (sender says 36m.) I am at a few feet above sea level.
