i am trying to implement AoA in nrf52833 in PlatformIO, the board is added. And i couldn’t find macro definition for LE Set Connectionless CTE Transmit Parameters command and LE Set Connectionless CTE Transmit Enable command in the …platformio\packages\framework-zephyr\include\bluetooth\hci.h
Where it will be available?
What file content should be there? Is it included in newer Zephyr versions?
Example:
#define BT_HCI_OP_LE_SET_PER_ADV_PARAM BT_OP(BT_OGF_LE, 0x003e)
taken from hci.h file
To establish Connectionless AoA/AoD- Advertising
the procedure to configure host in the ADVERTISING DEVICE side and corresponding macro definition in the hci.h file
Configure extended advertising-BT_HCI_OP_LE_SET_EXT_ADV_PARAM
Configure periodic advertising- BT_HCI_OP_LE_SET_PER_ADV_PARAM
Configure CTE transmission - not defined
Enable CTE advertising - not defined
Enable periodic advertising - BT_HCI_OP_LE_SET_PER_ADV_ENABLE
Enable extended advertising - BT_HCI_OP_LE_SET_EXT_ADV_ENABLE
Set the advertising data - BT_HCI_OP_LE_SET_PER_ADV_DATA
I think it is not ! or may be , but i have searched for it. Could not get it.
So it seems that you’re searching for functionality in Zephyr’s Bluetooth / BLE stack which isn’t there. Its stack seems to have originally come from Intel
https://github.com/zephyrproject-rtos/zephyr/blob/master/include/bluetooth/hci.h#L4
I think it’s best to ask the developers at Zephyr regarding that functionality you want to have (Issues · zephyrproject-rtos/zephyr · GitHub).
Is it required to get some example to compile or is this experimental functionality you want to have?
Ok I ll ask them,
It is required for my project. We want to develop RTLS and Proximity /assert tracking using this nrf52833 board
