This is my code
#include "stm32yyxx_ll.h"
#include "Arduino.h"
#include "dwt_stm32_delay.h"
#define USE_DSHOT
#define USE_DSHOT_DMAR
#define MAX_SUPPORTED_MOTORS 8
#define MOTOR_BIT_0 7
#define MOTOR_BIT_1 14
#define MOTOR_BITLENGTH 19
#define DSHOT_DMA_BUFFER_SIZE 18 /* resolution + frame reset (2us) */
uint32_t dmaBufferT3CH1[DSHOT_DMA_BUFFER_SIZE];
uint32_t dmaBufferT3CH2[DSHOT_DMA_BUFFER_SIZE];
uint32_t dmaBufferT4CH1[DSHOT_DMA_BUFFER_SIZE];
uint32_t dmaBufferT4CH2[DSHOT_DMA_BUFFER_SIZE];
// IO pin identification
// make sure that ioTag_t can't be assigned into IO_t without warning
typedef uint8_t ioTag_t; // packet tag to specify IO pin
typedef void* IO_t; // type specifying IO pin. Currently ioRec_t pointer, but this may change
typedef uint8_t ioConfig_t; // packed IO configuration
// DEF_TIM(TIM3, CH1, PB4, TIM_USE_MOTOR, 0, 0), // S1_OUT
// DEF_TIM(TIM3, CH2, PB5, TIM_USE_MOTOR, 0, 0), // S2_OUT
// DEF_TIM(TIM4, CH1, PB6, TIM_USE_MOTOR, 0, 0), // S3_OUT
// DEF_TIM(TIM4, CH2, PB7, TIM_USE_MOTOR, 0, 0), // S4_OUT
int cnt = 0;
int32_t Timer1;
int32_t Timer2;
int32_t Timer3;
int32_t Timer4;
#define testLoop1_Pin PB6
#define testLoop1_Port GPIOB
#define testLoop1_PinNum LL_GPIO_PIN_6
#define testLoop2_Pin PB7
#define testLoop2_Port GPIOB
#define testLoop2_PinNum LL_GPIO_PIN_7
// STM32F411 Reference Manual RM0383 pp.170
extern "C" void DMA1_Stream0_IRQHandler(void) {
//LL_GPIO_SetOutputPin(testLoop1_Port, testLoop1_PinNum);
if (LL_DMA_IsActiveFlag_TC0(DMA1)) {
LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_0);
LL_TIM_DisableDMAReq_CC1(TIM4);
LL_DMA_ClearFlag_TC0(DMA1);
//LL_GPIO_ResetOutputPin(testLoop1_Port, testLoop1_PinNum);
extern "C" void DMA1_Stream3_IRQHandler(void) {
if (LL_DMA_IsActiveFlag_TC3(DMA1)) {
LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_3);
LL_TIM_DisableDMAReq_CC2(TIM4);
LL_DMA_ClearFlag_TC3(DMA1);
extern "C" void DMA1_Stream4_IRQHandler(void) {
if (LL_DMA_IsActiveFlag_TC4(DMA1)) {
LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_4);
LL_TIM_DisableDMAReq_CC1(TIM3);
LL_DMA_ClearFlag_TC4(DMA1);
extern "C" void DMA1_Stream5_IRQHandler(void) {
//LL_GPIO_SetOutputPin(testLoop2_Port, testLoop2_PinNum);
if (LL_DMA_IsActiveFlag_TC5(DMA1)) {
LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_5);
LL_TIM_DisableDMAReq_CC2(TIM3);
LL_DMA_ClearFlag_TC5(DMA1);
//LL_GPIO_ResetOutputPin(testLoop2_Port, testLoop2_PinNum);
#define MHZ_TO_HZ(x) ((x) * 1000000)
#define MOTOR_DSHOT1200_HZ MHZ_TO_HZ(24)
#define MOTOR_DSHOT600_HZ MHZ_TO_HZ(12)
#define MOTOR_DSHOT300_HZ MHZ_TO_HZ(6)
#define MOTOR_DSHOT150_HZ MHZ_TO_HZ(3)
void pwmDshotMotorHardwareConfig(void) {
LL_GPIO_InitTypeDef GPIO_InitStruct;
// GPIO peripheral clock enable
//LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOB);
// TIM3 GPIO Configuration
GPIO_InitStruct.Pin = LL_GPIO_PIN_4 | LL_GPIO_PIN_5 | LL_GPIO_PIN_6 | LL_GPIO_PIN_7;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_LOW;
GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
GPIO_InitStruct.Alternate = LL_GPIO_AF_2;
LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
// TIM3 peripheral clock enable
LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM3);
LL_TIM_DisableCounter(TIM3);
// TIM4 peripheral clock enable
LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM4);
LL_TIM_DisableCounter(TIM4);
LL_TIM_InitTypeDef TIM_TimeBaseStructure;
LL_TIM_StructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.Prescaler = (uint16_t)(((float) 100000000 / MOTOR_DSHOT600_HZ + 0.01f) - 1);
TIM_TimeBaseStructure.Autoreload = MOTOR_BITLENGTH;
TIM_TimeBaseStructure.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
TIM_TimeBaseStructure.RepetitionCounter = 0;
TIM_TimeBaseStructure.CounterMode = LL_TIM_COUNTERMODE_UP;
LL_TIM_Init(TIM3, &TIM_TimeBaseStructure);
LL_TIM_Init(TIM4, &TIM_TimeBaseStructure);
LL_TIM_OC_InitTypeDef TIM_OCInitStructure;
LL_TIM_OC_StructInit(&TIM_OCInitStructure);
TIM_OCInitStructure.OCMode = LL_TIM_OCMODE_PWM1;
TIM_OCInitStructure.OCState = LL_TIM_OCSTATE_ENABLE;
TIM_OCInitStructure.OCIdleState = LL_TIM_OCIDLESTATE_HIGH;
TIM_OCInitStructure.OCPolarity = LL_TIM_OCPOLARITY_HIGH;
TIM_OCInitStructure.CompareValue = 0;
// Init TIM3 and TIM4 output compare channels
LL_TIM_OC_Init(TIM3, LL_TIM_CHANNEL_CH1, &TIM_OCInitStructure);
LL_TIM_OC_Init(TIM3, LL_TIM_CHANNEL_CH2, &TIM_OCInitStructure);
LL_TIM_OC_Init(TIM4, LL_TIM_CHANNEL_CH1, &TIM_OCInitStructure);
LL_TIM_OC_Init(TIM4, LL_TIM_CHANNEL_CH2, &TIM_OCInitStructure);
// TIM3 and TIM4 OC enable preload
LL_TIM_OC_EnablePreload(TIM3, LL_TIM_CHANNEL_CH1);
LL_TIM_OC_EnablePreload(TIM3, LL_TIM_CHANNEL_CH2);
LL_TIM_OC_EnablePreload(TIM4, LL_TIM_CHANNEL_CH1);
LL_TIM_OC_EnablePreload(TIM4, LL_TIM_CHANNEL_CH2);
// TIM3 and TIM4 OC enable channel
LL_TIM_CC_EnableChannel(TIM3, LL_TIM_CHANNEL_CH1);
LL_TIM_CC_EnableChannel(TIM3, LL_TIM_CHANNEL_CH2);
LL_TIM_CC_EnableChannel(TIM4, LL_TIM_CHANNEL_CH1);
LL_TIM_CC_EnableChannel(TIM4, LL_TIM_CHANNEL_CH2);
LL_TIM_EnableAllOutputs(TIM3);
LL_TIM_EnableARRPreload(TIM3);
LL_TIM_EnableCounter(TIM3);
LL_TIM_EnableAllOutputs(TIM4);
LL_TIM_EnableARRPreload(TIM4);
LL_TIM_EnableCounter(TIM4);
//---DMA-------------------------------------
LL_DMA_DeInit(DMA1, LL_DMA_STREAM_4);
LL_DMA_DeInit(DMA1, LL_DMA_STREAM_5);
LL_DMA_DeInit(DMA1, LL_DMA_STREAM_0);
LL_DMA_DeInit(DMA1, LL_DMA_STREAM_3);
LL_DMA_InitTypeDef DMA_InitStructure;
// DMA controller clock enable
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_DMA1);
NVIC_SetPriority(DMA1_Stream4_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 0, 0));
NVIC_EnableIRQ(DMA1_Stream4_IRQn);
NVIC_SetPriority(DMA1_Stream5_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 0, 0));
NVIC_EnableIRQ(DMA1_Stream5_IRQn);
NVIC_SetPriority(DMA1_Stream0_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 0, 0));
NVIC_EnableIRQ(DMA1_Stream0_IRQn);
NVIC_SetPriority(DMA1_Stream3_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 0, 0));
NVIC_EnableIRQ(DMA1_Stream3_IRQn);
//-DMA TIM3 CCR1-----------
LL_DMA_StructInit(&DMA_InitStructure);
DMA_InitStructure.Channel = LL_DMA_CHANNEL_5;
DMA_InitStructure.MemoryOrM2MDstAddress = (uint32_t)dmaBufferT3CH1;
DMA_InitStructure.Direction = LL_DMA_DIRECTION_MEMORY_TO_PERIPH;
DMA_InitStructure.FIFOMode = LL_DMA_FIFOMODE_ENABLE;
DMA_InitStructure.FIFOThreshold = LL_DMA_FIFOTHRESHOLD_1_4;
DMA_InitStructure.MemBurst = LL_DMA_MBURST_SINGLE;
DMA_InitStructure.PeriphBurst = LL_DMA_PBURST_SINGLE;
DMA_InitStructure.PeriphOrM2MSrcAddress = (uint32_t)&TIM3->CCR1;
DMA_InitStructure.NbData = DSHOT_DMA_BUFFER_SIZE;
DMA_InitStructure.PeriphOrM2MSrcIncMode = LL_DMA_PERIPH_NOINCREMENT;
DMA_InitStructure.MemoryOrM2MDstIncMode = LL_DMA_MEMORY_INCREMENT;
DMA_InitStructure.PeriphOrM2MSrcDataSize = LL_DMA_PDATAALIGN_WORD;
DMA_InitStructure.MemoryOrM2MDstDataSize = LL_DMA_MDATAALIGN_WORD;
DMA_InitStructure.Mode = LL_DMA_MODE_NORMAL;
DMA_InitStructure.Priority = LL_DMA_PRIORITY_HIGH;
LL_DMA_Init(DMA1, LL_DMA_STREAM_4, &DMA_InitStructure);
LL_DMA_EnableIT_TC(DMA1, LL_DMA_STREAM_4);
//-DMA TIM3 CCR2-----------
DMA_InitStructure.MemoryOrM2MDstAddress = (uint32_t)dmaBufferT3CH2;
DMA_InitStructure.PeriphOrM2MSrcAddress = (uint32_t)&TIM3->CCR2;
LL_DMA_Init(DMA1, LL_DMA_STREAM_5, &DMA_InitStructure);
LL_DMA_EnableIT_TC(DMA1, LL_DMA_STREAM_5);
//-DMA TIM4 CCR1-----------
DMA_InitStructure.Channel = LL_DMA_CHANNEL_2;
DMA_InitStructure.MemoryOrM2MDstAddress = (uint32_t)dmaBufferT4CH1;
DMA_InitStructure.PeriphOrM2MSrcAddress = (uint32_t)&TIM4->CCR1;
LL_DMA_Init(DMA1, LL_DMA_STREAM_0, &DMA_InitStructure);
LL_DMA_EnableIT_TC(DMA1, LL_DMA_STREAM_0);
//-DMA TIM4 CCR2-----------
DMA_InitStructure.MemoryOrM2MDstAddress = (uint32_t)dmaBufferT4CH2;
DMA_InitStructure.PeriphOrM2MSrcAddress = (uint32_t)&TIM4->CCR2;
LL_DMA_Init(DMA1, LL_DMA_STREAM_3, &DMA_InitStructure);
LL_DMA_EnableIT_TC(DMA1, LL_DMA_STREAM_3);
uint16_t prepareDshotPacket(uint16_t value, bool requestTelemetry) {
uint16_t packet = (value << 1) | (requestTelemetry ? 1 : 0);
requestTelemetry = false; // reset telemetry request to make sure it's triggered only once in a row
// compute checksum
int csum = 0;
int csum_data = packet;
for (int i = 0; i < 3; i++) {
csum ^= csum_data; // xor data by nibbles
csum_data >>= 4;
csum &= 0xf;
// append checksum
packet = (packet << 4) | csum;
return packet;
static uint8_t loadDmaBufferDshot(uint32_t *dmaBuffer, int stride, uint16_t packet) {
for (int i = 0; i < 16; i++) {
dmaBuffer[i * stride] = (packet & 0x8000) ? MOTOR_BIT_1 : MOTOR_BIT_0; // MSB first
packet <<= 1;
return DSHOT_DMA_BUFFER_SIZE;
Serial.print("Initializing...");
Serial.print(HAL_RCC_GetHCLKFreq());
Serial.println();
pinMode(LED_BUILTIN, OUTPUT);
DWT_Delay_Init();
pwmDshotMotorHardwareConfig();
uint16_t packet1, packet2, packet3, packet4;
uint8_t bufferSize1, bufferSize2, bufferSize3, bufferSize4;
packet1 = prepareDshotPacket( (cnt & 0b11111111111) , false);
bufferSize1 = loadDmaBufferDshot((uint32_t *)dmaBufferT3CH1, 1, packet1);
LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_4, bufferSize1);
packet2 = prepareDshotPacket( ((cnt + 1) & 0b11111111111) , false);
bufferSize2 = loadDmaBufferDshot((uint32_t *)dmaBufferT3CH2, 1, packet2);
LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_5, bufferSize2);
packet3 = prepareDshotPacket( ((cnt + 2) & 0b11111111111) , false);
bufferSize3 = loadDmaBufferDshot((uint32_t *)dmaBufferT4CH1, 1, packet3);
LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_0, bufferSize3);
packet4 = prepareDshotPacket( ((cnt + 3) & 0b11111111111) , false);
bufferSize4 = loadDmaBufferDshot((uint32_t *)dmaBufferT4CH2, 1, packet4);
LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_3, bufferSize4);
LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_4);
LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_5);
LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_0);
LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_3);
//TIM_SetCounter(dmaMotorTimers[i].timer, 0);
LL_TIM_SetCounter(TIM3, 0);
LL_TIM_SetCounter(TIM4, 0);
//TIM_DMACmd(dmaMotorTimers[i].timer, dmaMotorTimers[i].timerDmaSources, ENABLE);
LL_TIM_EnableDMAReq_CC1(TIM3);
LL_TIM_EnableDMAReq_CC2(TIM3);
LL_TIM_EnableDMAReq_CC1(TIM4);
LL_TIM_EnableDMAReq_CC2(TIM4);
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
DWT_Delay_us(12); // wait for fraction of a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
cnt++;
if (cnt > 2047) {
cnt = 0;
