hello,
I’m trying to convert my code from arduino Ide to PlatformIO,
When I build in the arduino ide:
I have an output:
The draft uses 1868233 bytes (95%) of the program’s storage space. The maximum is 1966080 bytes.
Global variables use 58688 bytes (17%) of dynamic memory, leaving 268992 bytes for local variables. The maximum is 327680 bytes.
->PlatformIO settings
I have an output:
Error: The program size (1972922 bytes) is greater than maximum allowed (1966080 bytes)
RAM: [== ] 19.9% (used 65088 bytes from 327680 bytes)
*** [checkprogsize] Explicit exit, status 1
Flash: [==========] 100.3% (used 1972922 bytes from 1966080 bytes)
I would like your help to be able to compile on PlatformIO
