Hello
i get confused problems with compile my arduino code
thats the errors
indent preformatted text by 4 spaces
Compiling .pio\build\megaatmega2560\lib69a\Adafruit Unified Sensor\Adafruit_Sensor.cpp.o
.pio\libdeps\megaatmega2560\MySQL Connector Arduino\src\MySQL_Encrypt_Sha1.cpp: In member function ‘virtual size_t Encrypt_SHA1::write(uint8_t)’:
.pio\libdeps\megaatmega2560\MySQL Connector Arduino\src\MySQL_Encrypt_Sha1.cpp:89:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\megaatmega2560\MySQL Connector Arduino\src\MySQL_Encrypt_Sha1.cpp: In member function ‘virtual size_t Encrypt_SHA1::write(uint8_t*, int)’:
.pio\libdeps\megaatmega2560\MySQL Connector Arduino\src\MySQL_Encrypt_Sha1.cpp:95:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\megaatmega2560\MySQL Connector Arduino\src\MySQL_Packet.cpp: In member function ‘int MySQL_Packet::read_lcb_int(int)’:
.pio\libdeps\megaatmega2560\MySQL Connector Arduino\src\MySQL_Packet.cpp:523:7: warning: unused variable ‘size’ [-Wunused-variable]
int size = 0;
Compiling .pio\build\megaatmega2560\lib8d4\Adafruit BusIO@src-1c59a2908cd7e8f991f92381d560d371\Adafruit_BusIO_Register.cpp.o
Compiling .pio\build\megaatmega2560\lib8d4\Adafruit BusIO@src-1c59a2908cd7e8f991f92381d560d371\Adafruit_I2CDevice.cpp.o
Archiving .pio\build\megaatmega2560\lib69a\libAdafruit Unified Sensor.a
Archiving .pio\build\megaatmega2560\lib28c\libMySQL Connector Arduino.a
In file included from .pio\libdeps\megaatmega2560\Adafruit BusIO@src-1c59a2908cd7e8f991f92381d560d371/Adafruit_BusIO_Register.h:1:0,
from .pio\libdeps\megaatmega2560\Adafruit BusIO@src-1c59a2908cd7e8f991f92381d560d371\Adafruit_BusIO_Register.cpp:1:
.pio\libdeps\megaatmega2560\Adafruit BusIO@src-1c59a2908cd7e8f991f92381d560d371/Adafruit_I2CDevice.h:1:10: fatal error: Wire.h: No such file or directory
- Looking for Wire.h dependency? Check our library registry!
- CLI > platformio lib search “header:Wire.h”
- Web > PlatformIO Registry
#include <Wire.h>
compilation terminated.
In file included from .pio\libdeps\megaatmega2560\Adafruit BusIO@src-1c59a2908cd7e8f991f92381d560d371\Adafruit_I2CDevice.cpp:1:0:
#include <Wire.h>
*** [.pio\build\megaatmega2560\lib8d4\Adafruit BusIO@src-1c59a2908cd7e8f991f92381d560d371\Adafruit_BusIO_Register.cpp.o] Error 1
*** [.pio\build\megaatmega2560\lib8d4\Adafruit BusIO@src-1c59a2908cd7e8f991f92381d560d371\Adafruit_I2CDevice.cpp.o] Error 1
================================================================================== [FAILED] Took 5.72 seconds ==================================================================================
and that my platformio.ini
[env:megaatmega2560]
board = megaatmega2560
paulstoffregen/Ethernet@0.0.0-alpha+sha.9f41e8231b
arduino-libraries/Ethernet@^2.0.0
milesburton/DallasTemperature@^3.9.1
paulstoffregen/TimeAlarms@0.0.0-alpha+sha.c291c1ddad
thomasfredericks/Bounce2@^2.70
paulstoffregen/Time@^1.6.1
chuckbell/MySQL Connector Arduino@^1.2.0
adafruit/Adafruit Unified Sensor@^1.1.4
adafruit/Adafruit BME680 Library@^2.0.1
paulstoffregen/OneWire@^2.3.5
https://github.com/PaulStoffregen/Wire.git
https://github.com/SodaqMoja/Sodaq_SHT2x.git
https://github.com/adafruit/Adafruit_BusIO.git
lib_ignore =
Wire
i tried a lot with lib_ignore but nothing work
i not understand why compile in Ardino-IDE well and from some years in platformio too… but now nothing from my old codes work more in platformio
Regards
Achim
