Confused about README in the lib folder regarding library.json
the initial readme file in the lib folder
the thing is library.json indicate that default directure structure assume that there would be an include dir for header files, while this readme states that the default structure has both includes and src files in the same directory, so which is it?
The source code of each library should be placed in a an own separate directory
("lib/your_library_name/[here are source files]").
For example, see a structure of the following two libraries `Foo` and `Bar`:
|--lib
|  |--Bar
|  |  |--docs
|  |  |--examples
|  |  |--src
|  |     |- Bar.c
|  |     |- Bar.h
|  |  |- library.json (optional, custom build options, etc) https://docs.platformio.org/page/librarymanager/config.html
|  |--Foo
|  |  |- Foo.c
|  |  |- Foo.h
|  |- README --> THIS FILE
|- platformio.ini
|--src
   |- main.c
Both are accepted forms.
