I’ve been having trouble compiling for a while. Code that used to always compile without any problems now breaks because files were not found. But these are files from unused parts of the library that shouldn’t actually be compiled.
[ [env:az-delivery-devkit-v4]
board = az-delivery-devkit-v4
adafruit/Adafruit BNO055@^1.5.3
adafruit/Adafruit Unified Sensor@^1.1.5
Processing az-delivery-devkit-v4 (platform: espressif32; board: az-delivery-devkit-v4; framework: arduino)
Verbose mode can be enabled via
-v, --verbose
option
CONFIGURATION:
PLATFORM: Espressif 32 (3.5.0) > AZ-Delivery ESP-32 Dev Kit C V4
HARDWARE: ESP32 240MHz, 520KB RAM, 16MB Flash
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
LDF: Library Dependency Finder →
Found 31 compatible libraries
Scanning dependencies…
|-- 1.5.3
| |-- 1.11.6
| | |-- 1.0.1
| |-- 1.0.1
| |-- 1.1.5
|-- 1.1.5
|-- 1.0.3
|-- 1.0.1
Compiling .pio/build/az-delivery-devkit-v4/src/main.cpp.o
Generating partitions .pio/build/az-delivery-devkit-v4/partitions.bin
Compiling .pio/build/az-delivery-devkit-v4/libd2e/Wire/Wire.cpp.o
Compiling .pio/build/az-delivery-devkit-v4/lib997/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
Compiling .pio/build/az-delivery-devkit-v4/lib997/Adafruit BusIO/Adafruit_I2CDevice.cpp.o
Compiling .pio/build/az-delivery-devkit-v4/lib997/Adafruit BusIO/Adafruit_SPIDevice.cpp.o
In file included from .pio/libdeps/az-delivery-devkit-v4/Adafruit BusIO/Adafruit_BusIO_Register.h:10:0,
from .pio/libdeps/az-delivery-devkit-v4/Adafruit BusIO/Adafruit_BusIO_Register.cpp:1:
.pio/libdeps/az-delivery-devkit-v4/Adafruit BusIO/Adafruit_SPIDevice.h:9:17: fatal error: SPI.h: No such file or directory
- Looking for SPI.h dependency? Check our library registry!
- CLI > platformio lib search “header:SPI.h”
- Web > PlatformIO Registry
compilation terminated.
Compiling .pio/build/az-delivery-devkit-v4/lib45f/Adafruit Unified Sensor/Adafruit_Sensor.cpp.o
In file included from .pio/libdeps/az-delivery-devkit-v4/Adafruit BusIO/Adafruit_SPIDevice.cpp:1:0:
- Web >
Compiling .pio/build/az-delivery-devkit-v4/lib09c/Adafruit BNO055/Adafruit_BNO055.cpp.o
*** [.pio/build/az-delivery-devkit-v4/lib997/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o] Error 1
*** [.pio/build/az-delivery-devkit-v4/lib997/Adafruit BusIO/Adafruit_SPIDevice.cpp.o] Error 1
======================================================= [FAILED] Took 2.50 seconds =======================================================
Der Terminalprozess “platformio ‘run’” wurde mit folgendem Exitcode beendet: 1.Das Terminal wird von Aufgaben wiederverwendet, drücken Sie zum Schließen eine beliebige Taste.
Executing task in folder TestBNO: platformio run <
-v, --verbose
option
CONFIGURATION:
|-- 1.5.3
| |-- 1.11.6
| | |-- 1.0.1
| |-- 1.0.1
| |-- 1.1.5
|-- 1.1.5
|-- 1.0.3
|-- 1.0.1
- Web >
======================================================= [FAILED] Took 2.55 seconds =======================================================
