I am trying to program a ESP32 to replace a controller that failed on my solar tracker. The original controller is not currently available due to the chip shortage. There is a algorithm written by NREL that does a great job calculating the current sun position. Their test program runs great on CodeBlocks IDE but I get compile errors when I try to run it in PlatformIO.
Here is the output when trying to compile:
Found 32 compatible libraries
Compiling .pio\build\esp32dev\src\main.cpp.o
Linking .pio\build\esp32dev\firmware.elf
c:/users/bdrma/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\main.cpp.o:(.literal._Z5setupv+0x50): undefined reference to `spa_calculate(spa_data*)'
c:/users/bdrma/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\main.cpp.o: in function `setup()':
C:\Users\bdrma\Documents\PlatformIO\Projects\spatest/src/main.cpp:42: undefined reference to `spa_calculate(spa_data*)'
*** [.pio\build\esp32dev\firmware.elf] Error 1
I put “spa.h” in the project include folder and “spa.c” in the src folder.
Can someone Please point out what I am doing wrong?
Here is the main.c file:
#include <stdlib.h>
#include <stdio.h>
#include "spa.h" //include the SPA header file
int result;
spa_data spa; //declare the SPA structure
void setup()
//enter required input values into SPA structure
spa.year = 2022;
spa.month = 8;
spa.day = 4;
spa.hour = 13;
spa.minute = 14;
spa.second = 0;
spa.timezone = -5.0;
spa.delta_ut1 = 0;
spa.delta_t = 67;
spa.longitude = 90.7;
spa.latitude = 41.513;
spa.elevation = 990.0;
spa.pressure = 820;
spa.temperature = 11;
spa.slope = 30;
spa.azm_rotation = -10;
spa.atmos_refract = 0.5667;
spa.function = SPA_ZA;
result = spa_calculate(&spa);
if (result == 0) //check for SPA errors
//display the results inside the SPA structure
printf("Epsilon: %.6f degrees\n",spa.epsilon);
printf("Zenith: %.6f degrees\n",spa.zenith);
printf("Azimuth: %.6f degrees\n",spa.azimuth);
} else printf("SPA Error Code: %d\n", result);
void loop()
