hello good afternoon, could anyone help me ?, I have the following error when trying to use the AsyncTCP library in a project with esp32;
.piolibdeps \ AsyncTCP \ src \ AsyncTCP.cpp: 201: 141: error: ‘xTaskCreateUniversal’ was not declared in this scope.
Thank you.
The root problem is AsyncTCP 1.1.0 introduced changes requiring stuff added in the arduino esp32 core 1.0.2. PlatformIO supports arduino-esp32 1.0.2 as of platform-espressif32 1.8.0, so you can either run a platformio update
to ensure all your platform files and libraries are up to date, or you can update the platformio.ini
for your project and change the platform = espressif32
to platform = espressif32@>1.8.0
and platformio will ensure the needed platform version is used.
Alternately, you can ensure that only a pre 1.1.0 version of AsyncTCP is used, similar to the esphome project, by putting
AsyncTCP@<1.1.0
in your platformio.ini
thank you
I did what he told me and it worked very well
thanks again
