I try to build example code and getting still the same error. I tried to reinstall VS Code and PlatformIO as well. 2 months ago everything worked!
platformio.ini:
[env]
extra_scripts =
pre:/$PROJECT_LIBDEPS_DIR/$PIOENV/ulptool-pio/pre_extra_script_ulptool.py
post:/$PROJECT_LIBDEPS_DIR/$PIOENV/ulptool-pio/post_extra_script_ulptool.py
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
dawidchyrzynski/home-assistant-integration@^1.3.0
likeablob/ulptool-pio@^0.1.0
Build:
> Executing task in folder ulp-counter: platformio run --environment esp32dev <
Processing esp32dev (board: esp32dev; platform: espressif32; framework: arduino)
PLATFORM: Espressif 32 (4.4.0) > Espressif ESP32 Dev Module
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20003.0 (2.0.3)
Found 33 compatible libraries
|-- ulptool-pio @ 0.1.0+sha.7c5dd85
cb([".pio/build/esp32dev/firmware.elf"], [".pio/build/esp32dev/src/ulp_counter.cpp.o"])
Running ulptool
*** [.pio/build/esp32dev/firmware.elf] KeyError : 'toolchain-xtensa32'
File "/home/pavel/.platformio/packages/tool-scons/scons-local-4.3.0/SCons/Action.py", line 1279, in execute
result = self.execfunction(target=target, source=rsources, env=env)
File "/home/pavel/Dokumenty/PlatformIO/Projects/ulp-counter/.pio/libdeps/esp32dev/ulptool-pio/post_extra_script_ulptool.py", line 59, in cb
run_ulptool()
File "/home/pavel/Dokumenty/PlatformIO/Projects/ulp-counter/.pio/libdeps/esp32dev/ulptool-pio/post_extra_script_ulptool.py", line 24, in run_ulptool
toolchain_xtensa_dir = platform.get_package_dir("toolchain-xtensa32")
File "/home/pavel/.platformio/penv/lib/python3.8/site-packages/platformio/platform/_packages.py", line 32, in get_package_dir
pkg = self.get_package(name)
File "/home/pavel/.platformio/penv/lib/python3.8/site-packages/platformio/platform/_packages.py", line 29, in get_package
return self.pm.get_package(spec or self.get_package_spec(name))
File "/home/pavel/.platformio/penv/lib/python3.8/site-packages/platformio/platform/_packages.py", line 21, in get_package_spec
owner=self.packages[name].get("owner"),
KeyError: 'toolchain-xtensa32'
=========================================================== [FAILED] Took 1.63 seconds ======
