I am trying to compile ESPhome on ESPDUINO 32 HW 707 but I get the following compilation errors:
|-- <AsyncTCP-esphome> 1.1.1
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
Compiling .pioenvs/sens_d1_02/FrameworkArduino/wiring_pulse.c.o
Compiling .pioenvs/sens_d1_02/FrameworkArduino/wiring_shift.c.o
In file included from /root/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:185:0,
from /root/.platformio/packages/framework-arduinoespressif32/cores/esp32/wiring_private.h:31,
from /root/.platformio/packages/framework-arduinoespressif32/cores/esp32/wiring_pulse.c:18:
/root/.platformio/packages/framework-arduinoespressif32/variants/d-duino-32/pins_arduino.h:61:33: error: initializer element is not constant
static const uint8_t OLED_SCL = SCL;
/root/.platformio/packages/framework-arduinoespressif32/variants/d-duino-32/pins_arduino.h:62:33: error: initializer element is not constant
static const uint8_t OLED_SDA = SDA;
*** [.pioenvs/sens_d1_02/FrameworkArduino/wiring_pulse.c.o] Error 1
from /root/.platformio/packages/framework-arduinoespressif32/cores/esp32/wiring_shift.c:21:
*** [.pioenvs/sens_d1_02/FrameworkArduino/wiring_shift.c.o] Error 1
====================================== [FAILED] Took 8.90 seconds ======================================
My test YAML begins with:
esphome:
- name: sens_d1_02*
- platform: ESP32*
- board: d-duino-32*
Can anyone help with this error? I managed to compile it by commenting out the two lines that contain the SCL/SDA entries @ /root/.platformio/packages/framework-arduinoespressif32/variants/d-duino-32/pins_arduino.h.
Other version information:
esphome version: 1.15.1
board: d-duino-32
arduino_version: espressif32@1.12.4
PlatformIO version: 4.3.4
