Executing task in folder argb: C:\Users\Max\.platformio\penv\Scripts\platformio.exe run <
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.4.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Found 6 compatible libraries
|-- <Adafruit NeoPixel> 1.10.3
Linking .pio\build\uno\firmware.elf
C:\Users\Max\AppData\Local\Temp\cc8zFjJd.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x86): undefined reference to `setup'
<artificial>:(.text.startup+0x8e): undefined reference to `loop'
*** [.pio\build\uno\firmware.elf] Error 1
============================================================================================================================================= [FAILED] Took 0.88 seconds =============================================================================================================================================
The terminal process "C:\Users\Max\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
I already tried to google my way out, but i cant find a working fix for this. I get this error when i try to verify or upload any code. It also looks like its generating “problems” in code wich is already able to run on a arduino.
Besides this it realy likes german, everytime i launch the programm it asks to get restarted to install the german language pack, wich i always uninstall because errors in german make even less sence than in english
The working code wich trows some kind of include error:
// A basic everyday NeoPixel strip test program.
// NEOPIXEL BEST PRACTICES for most reliable operation:
// - Add 1000 uF CAPACITOR between NeoPixel strip's + and - connections.
// - MINIMIZE WIRING LENGTH between microcontroller board and first pixel.
// - NeoPixel strip's DATA-IN should pass through a 300-500 OHM RESISTOR.
// - AVOID connecting NeoPixels on a LIVE CIRCUIT. If you must, ALWAYS
// connect GROUND (-) first, then +, then data.
// - When using a 3.3V microcontroller with a 5V-powered NeoPixel strip,
// a LOGIC-LEVEL CONVERTER on the data line is STRONGLY RECOMMENDED.
// (Skipping these may work OK on your workbench but can fail in the field)
//#include <Arduino.h>
#include <Adafruit_NeoPixel.h>
#idef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN 11
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 31
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
/* Argument 1 = Number of pixels in NeoPixel strip
Argument 2 = Arduino pin number (most are valid)
Argument 3 = Pixel type flags, add together as needed:
NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products) */
void setup() { //function -- runs once at startup --------------------------------
int CounterA = 0;
int CounterB = 0;
int ButtonA = 3;
int ButtonB = 4;
int Timer1 = 50;
int Timer2 = 125;
//int tempCounter = 0;
int ButtonA = digitalRead(3);
int ButtonB = digitalRead(4);
int state = Serial.parseInt();
CounterA = CounterA +1;
Serial.begin(9600);
while (!serial);
Serial.print("Reset");
// These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
// Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
// END of Trinket-specific code.
strip.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
strip.show(); // Turn OFF all pixels ASAP
strip.setBrightness(191); // Set BRIGHTNESS to 75% 191
pinMode(3, INPUT);
pinMode(4, INPUT);
// pinMode(7, OUTPUT);
Serial.println("↓");
Serial.print("CounterA: "); //debug
Serial.println(CounterA);
Serial.print("CounterB: ");
Serial.println(CounterB);
if(Serial.available()) {
int sate = Serial.parseInt();
if (state == 1) {
Serial.println("Serial In recived");
if (state == 2) {
CounterB = CounterB +1;
if(ButtonB == HIGH) {
if(CounterB == (2)) {
CounterB = CounterB -2;
delay(5000);
if(CounterB == (1)) {
rainbow(25);
if(ButtonA == HIGH) {
// tempCounter = tempCounter +1;
//tempCounter = tempCounter -1;
if(CounterB == (0)) {
if(CounterA == (0)) {
colorWipe(strip.Color( 0, 0, 0),Timer1); //RBG
if(CounterA == (2)) {
colorWipe2(strip.Color( 0, 255, 150),Timer1); //RBG
Serial.print("Farbwechsel, 0, 255, 150");
if(CounterA == (3)) {
if(CounterA == (4)) {
colorWipe(strip.Color( 0, 255, 20),Timer1); //RBG
Serial.print("Farbwechsel, 0, 255, 20");
if(CounterA == (6)) {
colorWipe2(strip.Color(255, 0, 0),Timer1); //RBG
Serial.println("Farbwechsel, 255, 0, 0");
if(CounterA == (8)) {
colorWipe(strip.Color( 0, 255, 0),Timer1); //RBG
Serial.println("Farbwechsel, 0, 255, 0");
if(CounterA == (10)) {
colorWipe2(strip.Color( 0, 0, 255),Timer1); //RBG
Serial.println("Farbwechsel, 0, 0, 255");
if(CounterA == (12)) {
colorWipe(strip.Color(255, 255, 0),Timer1); //RBG
Serial.println("Farbwechsel, 255, 255, 0");
if(CounterA == (14)) {
colorWipe2(strip.Color( 0, 255, 255),Timer1); //RBG
Serial.println("Farbwechsel, 0, 255, 255");
if(CounterA == (16)) {
colorWipe(strip.Color(255, 0, 255),Timer1); //RBG
Serial.println("Farbwechsel, 255, 0, 255");
if(CounterA == (18)) {
colorWipe2(strip.Color(255, 255, 255),Timer1); //RBG
Serial.println("Farbwechsel 255 255 255");
if(CounterA == (20)) {
colorWipe(strip.Color( 0, 150, 75),Timer1); //RBG
if(CounterA == (22)) {
theaterChase(strip.Color( 0, 255, 150),Timer2); //RBG
if(CounterA ==(24)) {
theaterChase2(strip.Color( 0, 255, 150),Timer2); //RBG
if(CounterA ==(12)) {
CounterA = CounterA -12; //Return to 0
// Do a theater marquee effect in various colors...
//theaterChase(strip.Color(0, 255, 0), 75); // Green, half brightness
// theaterChase(strip.Color(255, 0, 0), 75); // Red, half brightness
// theaterChase(strip.Color( 0, 0, 255), 75); // Blue, half brightness
// rainbow(25);
// rainbowCycle(30);// Flowing rainbow cycle along the whole strip
// theaterChaseRainbow(50); // Rainbow-enhanced theaterChase variant
// colorWave(50);
/* digitalWrite(7, HIGH); //debug
delay(100);
digitalWrite(7, LOW);*/
void update() {
Serial.println("update"); //debug
//tempCounter = tempCounter +1;
// Some functions of our own for creating animated effects -----------------
// Fill strip pixels one after another with a color. Strip is NOT cleared
// first; anything there will be covered pixel by pixel. Pass in color
// (as a single 'packed' 32-bit value, which you can get by calling
// strip.Color(red, green, blue) as shown in the loop() function above),
// and a delay time (in milliseconds) between pixels.
void colorWipe(uint32_t color, int wait) {
for (int i = 0; i < strip.numPixels(); i++) { // For each pixel in strip...
strip.setPixelColor(i, color); // Set pixel's color (in RAM)
strip.show(); // Update strip to match
delay(wait); // Pause for a moment
void colorWipe2(uint32_t color, int wait) {
strip.setPixelColor(strip.numPixels() - i-1, color); // Set pixel's color (in RAM)
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for (j = 0; j < 256 * 5; j++) { // 5 cycles of all colors on wheel
for (i = 0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
uint32_t Wheel(byte WheelPos) {
if (WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if (WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
----------ColorWave---------
void colorWave(uint8_t wait) {
int i, j, stripsize, cycle;
float ang, rsin, gsin, bsin, offset;
static int tick = 0;
stripsize = strip.numPixels();
cycle = stripsize * 5; // times around the circle...
while (++tick % cycle) {
offset = map2PI(tick);
for (i = 0; i < stripsize; i++) {
ang = map2PI(i) - offset;
rsin = sin(ang);
gsin = sin(2.0 * ang / 3.0 + map2PI(int(stripsize / 6)));
bsin = sin(4.0 * ang / 5.0 + map2PI(int(stripsize / 3)));
strip.setPixelColor(i, strip.Color(trigScale(rsin), trigScale(gsin), trigScale(bsin)));
strip.show();
delay(wait);
Scale a value returned from a trig function to a byte value.
[-1, +1] -> [0, 254]
Note that we ignore the possible value of 255, for efficiency,
and because nobody will be able to differentiate between the
brightness levels of 254 and 255.
byte trigScale(float val) {
val += 1.0; // move range to [0.0, 2.0]
val *= 127.0; // move range to [0.0, 254.0]
return int(val) & 255;
Map an integer so that [0, striplength] -> [0, 2PI]
float map2PI(int i) {
return PI * 2.0 * float(i) / float(strip.numPixels());
// Theater-marquee-style chasing lights. Pass in a color (32-bit value,
// a la strip.Color(r,g,b) as mentioned above), and a delay time (in ms)
// between frames.
void theaterChase(uint32_t color, int wait) {
for (int a = 0; a < 10; a++) { // Repeat 10 times...
for (int b = 0; b < 3; b++) { // 'b' counts from 0 to 2...
strip.clear(); // Set all pixels in RAM to 0 (off)
// 'c' counts up from 'b' to end of strip in steps of 3...
for (int c = b; c < strip.numPixels(); c += 3) {
strip.setPixelColor(c, color); // Set pixel 'c' to value 'color'
strip.show(); // Update strip with new contents
a = a-10;
void theaterChase2(uint32_t color, int wait) {
for (int a = 0; a < 10; a++) { // Repeat 10 times... default 0, 10
for (int b = 0; b < 4; b++) { // 'b' counts from 0 to 2... default 0, 3
strip.setPixelColor(strip.numPixels() -c-1, color); // Set pixel 'c' to value 'color' -1 fix for the first led not chaning
// Rainbow cycle along whole strip. Pass delay time (in ms) between frames.
void rainbow(int wait) {
// Hue of first pixel runs 5 complete loops through the color wheel.
// Color wheel has a range of 65536 but it's OK if we roll over, so
// just count from 0 to 5*65536. Adding 256 to firstPixelHue each time
// means we'll make 5*65536/256 = 1280 passes through this outer loop:
for (long firstPixelHue = 0; firstPixelHue < 5 * 65536; firstPixelHue += 256) {
// Offset pixel hue by an amount to make one full revolution of the
// color wheel (range of 65536) along the length of the strip
// (strip.numPixels() steps):
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
update();
// strip.ColorHSV() can take 1 or 3 arguments: a hue (0 to 65535) or
// optionally add saturation and value (brightness) (each 0 to 255).
// Here we're using just the single-argument hue variant. The result
// is passed through strip.gamma32() to provide 'truer' colors
// before assigning to each pixel:
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
update();
// Rainbow-enhanced theater marquee. Pass delay time (in ms) between frames.
void theaterChaseRainbow(int wait) {
int firstPixelHue = 0; // First pixel starts at red (hue 0)
for (int a = 0; a < 30; a++) { // Repeat 30 times...
// 'c' counts up from 'b' to end of strip in increments of 3...
// hue of pixel 'c' is offset by an amount to make one full
// revolution of the color wheel (range 65536) along the length
// of the strip (strip.numPixels() steps):
int hue = firstPixelHue + c * 65536L / strip.numPixels();
uint32_t color = strip.gamma32(strip.ColorHSV(hue)); // hue -> RGB
firstPixelHue += 65536 / 90; // One cycle of color wheel over 90 frames
