Hello Everyone,
I am trying to fix a linking error with platformio. However, I encountered an error below.
Not sure where these errors are coming from. I just used platformio 3 months ago and I am not really an expert in using the tools.
* The terminal process "C:\Users\leo_a\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
* Executing task in folder ProteusBard: C:\Users\leo_a\.platformio\penv\Scripts\platformio.exe run
Processing megaatmega1280 (platform: atmelavr; board: megaatmega1280; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega1280.html
PLATFORM: Atmel AVR (4.0.0) > Arduino Mega or Mega 2560 ATmega1280
HARDWARE: ATMEGA1280 16MHz, 8KB RAM, 124KB Flash
- framework-arduino-avr @ 5.1.0
Converting DC1902_ProteusBard.ino
Found 10 compatible libraries
|-- SdFat @ 2.1.2
| |-- SPI @ 1.0
|-- genieArduino @ 1.5.3
|-- ElapsedMillis
|-- EEPROM @ 2.0
|-- SPI @ 1.0
|-- Firmata
|-- Wire @ 1.0
Compiling .pio\build\megaatmega1280\src\DC1902_ProteusBard.ino.cpp.o
Linking .pio\build\megaatmega1280\firmware.elf
.pio\build\megaatmega1280\src\datalogger.cpp.o (symbol from plugin): In function `portB':
(.text+0x0): multiple definition of `__vector_9'
.pio\build\megaatmega1280\src\DC1902_ProteusBard.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_10'
(.text+0x0): multiple definition of `__vector_11'
(.text+0x0): multiple definition of `HandleInterruptRadCount()'
*** [.pio\build\megaatmega1280\firmware.elf] Error 1
