- Arduino core 2.0.0 support is not stable yet and the above
platform_packages
is a hack (Support for the latest Arduino v2.0 · Issue #619 · platformio/platform-espressif32 · GitHub) - Using the 8.4.2 compiler from the PlatformIO repositories did not work me when using 2.0.0, see Use different version of Arduino framework on espressif platform - #6 by maxgerhardt
- If it stills fail at linking, check if
std::to_string
works in the Arduino-IDE for Arduino-ESP32. If it also fails → bug report to Arduino-ESP32, work-aroundstd::to_string
usage (e.g., construct a simple ArduinoString
object from the to-be-converted parameter, then.c_str()
it). If it works in the Arduino-IDE, wait for proper Arduino core 2.0.0 integration or avoidstd::to_string
usage.
