Collect2: error: ld returned 1 exit status *** [.pio/build/lilygo-t-display-s3/firmware.elf] Error 1
Hello, I am trying to convert this Arduino sketch to VSCode / Plateformio but I get this compiling error. I don’t understand the error found in this library Async WebServer.
The sketch is for ESP32: Create a Wi-Fi Manager
https://randomnerdtutorials.com/esp32-wi-fi-manager-asyncwebserver/
p.s.: I think I have declared all functions properly in the conversion.
I would appreciate some help on this one.
Linking .pio/build/lilygo-t-display-s3/firmware.elf
/home/sergio/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pio/build/lilygo-t-display-s3/libca1/libESP Async WebServer.a(WebAuthentication.cpp.o):(.literal._ZL6getMD5PhtPc+0x4): undefined reference to `mbedtls_md5_starts'
/home/sergio/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pio/build/lilygo-t-display-s3/libca1/libESP Async WebServer.a(WebAuthentication.cpp.o): in function `getMD5(unsigned char*, unsigned short, char*)':
/home/sergio/Documents/PlatformIO/Projects/WebManager_Test/.pio/libdeps/lilygo-t-display-s3/ESP Async WebServer/src/WebAuthentication.cpp:73: undefined reference to `mbedtls_md5_starts'
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#include <AsyncTCP.h>
#include "SPIFFS.h"
#include <TFT_eSPI.h>
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
// Search for parameter in HTTP POST request
const char* PARAM_INPUT_1 = "ssid";
const char* PARAM_INPUT_2 = "pass";
const char* PARAM_INPUT_3 = "ip";
const char* PARAM_INPUT_4 = "gateway";
void initSPIFFS();
String readFile(fs::FS &fs, const char * path);
void writeFile(fs::FS &fs, const char * path, const char * message);
bool initWiFi();
String processor(const String& var);
//Variables to save values from HTML form
String ssid;
String pass;
String ip;
String gateway;
// File paths to save input values permanently
const char* ssidPath = "/ssid.txt";
const char* passPath = "/pass.txt";
const char* ipPath = "/ip.txt";
const char* gatewayPath = "/gateway.txt";
IPAddress localIP;
//IPAddress localIP(192, 168, 1, 200); // hardcoded
// Set your Gateway IP address
IPAddress localGateway;
//IPAddress localGateway(192, 168, 1, 1); //hardcoded
IPAddress subnet(255, 255, 0, 0);
// Timer variables
unsigned long previousMillis = 0;
const long interval = 10000;  // interval to wait for Wi-Fi connection (milliseconds)
// Set LED GPIO
const int ledPin = 21;
// Stores LED state
String ledState;
  // Serial port for debugging purposes
  initSPIFFS();
  // Set GPIO 21 as an OUTPUT
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // Load values saved in SPIFFS
  ssid = readFile(SPIFFS, ssidPath);
  pass = readFile(SPIFFS, passPath);
  ip = readFile(SPIFFS, ipPath);
  gateway = readFile (SPIFFS, gatewayPath);
  Serial.println(ssid);
  Serial.println(pass);
  Serial.println(ip);
  Serial.println(gateway);
  if(initWiFi()) {
    // Route for root / web page
    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
      request->send(SPIFFS, "/index.html", "text/html", false, processor);
    server.serveStatic("/", SPIFFS, "/");
    // Route to set GPIO state to HIGH
    server.on("/on", HTTP_GET, [](AsyncWebServerRequest *request) {
      digitalWrite(ledPin, HIGH);
    // Route to set GPIO state to LOW
    server.on("/off", HTTP_GET, [](AsyncWebServerRequest *request) {
    server.begin();
  else {
    // Connect to Wi-Fi network with SSID and password
    Serial.println("Setting AP (Access Point)");
    // NULL sets an open Access Point
    WiFi.softAP("ESP-WIFI-MANAGER", NULL);
    IPAddress IP = WiFi.softAPIP();
    Serial.print("AP IP address: ");
    Serial.println(IP);
    // Web Server Root URL
    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
      request->send(SPIFFS, "/wifimanager.html", "text/html");
    server.on("/", HTTP_POST, [](AsyncWebServerRequest *request) {
      int params = request->params();
      for(int i=0;i<params;i++){
        AsyncWebParameter* p = request->getParam(i);
        if(p->isPost()){
          // HTTP POST ssid value
          if (p->name() == PARAM_INPUT_1) {
            ssid = p->value().c_str();
            Serial.print("SSID set to: ");
            // Write file to save value
            writeFile(SPIFFS, ssidPath, ssid.c_str());
          // HTTP POST pass value
          if (p->name() == PARAM_INPUT_2) {
            pass = p->value().c_str();
            Serial.print("Password set to: ");
            writeFile(SPIFFS, passPath, pass.c_str());
          // HTTP POST ip value
          if (p->name() == PARAM_INPUT_3) {
            ip = p->value().c_str();
            Serial.print("IP Address set to: ");
            Serial.println(ip);
            writeFile(SPIFFS, ipPath, ip.c_str());
          // HTTP POST gateway value
          if (p->name() == PARAM_INPUT_4) {
            gateway = p->value().c_str();
            Serial.print("Gateway set to: ");
            writeFile(SPIFFS, gatewayPath, gateway.c_str());
          //Serial.printf("POST[%s]: %s\n", p->name().c_str(), p->value().c_str());
      request->send(200, "text/plain", "Done. ESP will restart, connect to your router and go to IP address: " + ip);
      delay(3000);
      ESP.restart();
    server.begin();
// Initialize SPIFFS
void initSPIFFS() {
  if (!SPIFFS.begin(true)) {
    Serial.println("An error has occurred while mounting SPIFFS");
  Serial.println("SPIFFS mounted successfully");
// Read File from SPIFFS
String readFile(fs::FS &fs, const char * path){
  Serial.printf("Reading file: %s\r\n", path);
  File file = fs.open(path);
  if(!file || file.isDirectory()){
    Serial.println("- failed to open file for reading");
    return String();
  String fileContent;
  while(file.available()){
    fileContent = file.readStringUntil('\n');
    break;
  return fileContent;
// Write file to SPIFFS
void writeFile(fs::FS &fs, const char * path, const char * message){
  Serial.printf("Writing file: %s\r\n", path);
  File file = fs.open(path, FILE_WRITE);
  if(!file){
    Serial.println("- failed to open file for writing");
    return;
  if(file.print(message)){
    Serial.println("- file written");
  } else {
    Serial.println("- write failed");
// Initialize WiFi
bool initWiFi() {
  if(ssid=="" || ip==""){
    Serial.println("Undefined SSID or IP address.");
    return false;
  WiFi.mode(WIFI_STA);
  localIP.fromString(ip.c_str());
  localGateway.fromString(gateway.c_str());
  if (!WiFi.config(localIP, localGateway, subnet)){
    Serial.println("STA Failed to configure");
    return false;
  WiFi.begin(ssid.c_str(), pass.c_str());
  Serial.println("Connecting to WiFi...");
  unsigned long currentMillis = millis();
  previousMillis = currentMillis;
  while(WiFi.status() != WL_CONNECTED) {
    if (currentMillis - previousMillis >= interval) {
      Serial.println("Failed to connect.");
      return false;
  return true;
// Replaces placeholder with LED state value
String processor(const String& var) {
  if(var == "STATE") {
    if(digitalRead(ledPin)) {
      ledState = "ON";
    else {
      ledState = "OFF";
    return ledState;
  return String();
Hi @spirarementum
Please also show the content of your platformio.ini.
Here is plateform.ini
[env:lilygo-t-display-s3]
board = lilygo-t-display-s3
	me-no-dev/ESP Async WebServer@^1.2.3
	bodmer/TFT_eSPI@^2.5.43
Using the github version of ESPAsyncWebServer should fix the issue:
  https://github.com/me-no-dev/ESPAsyncWebServer.git
