The following code (copied from the web) makes a webserver that displays an simple website. When i compile and upload the code with the Arduino IDE the website loads. When i compile and upload the code with PlatformIO the website doesn’t load. Both times i get that the arduino connects to the WiFi.
Code:
* Created by ArduinoGetStarted.com
* This example code is in the public domain
* Tutorial page: https://arduinogetstarted.com/tutorials/arduino-web-server
#include <WiFiS3.h>
const char ssid[] = ""; // change your network SSID (name)
const char pass[] = ""; // change your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
float getTemperature() {
return 26.9456;
// YOUR SENSOR IMPLEMENTATION HERE
// simulate the temperature value
float temp_x100 = random(0, 10000); // a ramdom value from 0 to 10000
return temp_x100 / 100; // return the simulated temperature value from 0 to 100 in float
void printWifiStatus() {
// print your board's IP address:
Serial.print("IP Address: ");
// print the received signal strength:
Serial.print("signal strength (RSSI):");
Serial.print(WiFi.RSSI());
Serial.println(" dBm");
//Initialize serial and wait for port to open:
Serial.begin(9600);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION)
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin();
// you're connected now, so print out the status:
printWifiStatus();
// listen for incoming clients
WiFiClient client = server.available();
if (client) {
// read the HTTP request header line by line
while (client.connected()) {
if (client.available()) {
String HTTP_header = client.readStringUntil('\n'); // read the header line of HTTP request
if (HTTP_header.equals("\r")) // the end of HTTP request
break;
Serial.print("<< ");
Serial.println(HTTP_header); // print HTTP request to Serial Monitor
// send the HTTP response
// send the HTTP response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println(); // the separator between HTTP header and body
// send the HTTP response body
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head>");
client.println("<link rel=\"icon\" href=\"data:,\">");
client.println("</head>");
client.println("<p>");
client.print("Temperature: <span style=\"color: red;\">");
float temperature = getTemperature();
client.print(temperature, 2);
client.println("°C</span>");
client.println("</p>");
client.println("</html>");
client.flush();
// give the web browser time to receive the data
delay(10);
// close the connection:
client.stop();
